Suggest Don, that you check the voltage power rails in the Power Supply, first. Make sure the Power Supply is working correctly.
Power Supply voltages check out, look VERY close at the motherboard.
(Power unplugged to computer, Anti-Static Precautions taken, motherboard OUT in hand )
Reasoning?
http://www.e4allupgraders.info/dir1/motherboards/socketam2/ecsMCP61SM-GM.shtmleMachines are budget computers. Nothing wrong with that. Problem is the manufacturer saved the consumer on the cost, by using two low quality components.
A) The Power Supply
B) The motherboard
Both of these come up for the BIOS Beep Code you stated.
Power Supply's are usually Bestec, Delta, or HiPro.
These particular generic units use low quality Electrolytic Capacitors, MOSFET's, Rectifier Bridge, less than adequate gauge of wiring, and so on.
The motherboards, (MSI, ECS, TriGem, etc), use low quality Electrolytic Capacitors.
This is generally the item/s that go bad first. They are the 'weakest link'.
Yes, Electrolytic Capacitors are the weakest link in the Power Supply, also.
In the Power Supply they are used as Filters. They filter the incoming AC electricity, (Input Stage), and the outgoing DC electricity. (Output Stage)
http://en.wikipedia.org/wiki/Switched-mode_power_supplyI really feel the problem is the Power Supply.
Why?
1) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is. (Older Intel Pentium III's, II's, and so on, use less power than 51 Watts. Same with older AMD processors )
(The PSU { Power Supply Unit} in your personal computer is a SMPS.
Switched-Mode Power Supply)
Click on the photo to the upper right, in the link above. The letter B is on the top of an Electrolytic Capacitor. You are looking at a Top View.
The blue ring is part of a plastic sleeve, which goes around the 'can' case of the capacitor.
These large capacitors are in the Input Stage.
The letter E is near a few more Electrolytic Capacitors. These capacitors are in the Output Stage.
These capacitors are Radial Aluminum Electrolytic Capacitors.
This is a side view of an example,
http://en.wikipedia.org/wiki/File:Capacitors_electrolytic.jpgThe top capacitor is an Axial Electrolytic Capacitor. The leads come out of each end. The bottom capacitor is a Radial Electrolytic Capacitor. Both leads come out of the same end. The capacitors in your Power Supply, and on your motherboard, are Radial Aluminum Electrolytic Capacitors.
Your Power Supply converts AC electricity form your home, or business, and turns it into low DC electricity.
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail.
(In comparison two D cell flashlight batteries produce 3 Volts DC )
In the power cables coming from the Power Supply.
1) Orange wires are 3.3 Volts
2) Red wires are 5 Volts
3) Yellow wires are 12 Volts
(All DC voltage)
Black wires are Ground wires.
Now, about the voltage power rail.
All 3.3 volt wires (Orange), end in one central 3.3 Volt point, in the Power Supply.
The central point is the 3.3 Volt power rail.
Same for the 5 Volt power rail. All 5 Volt wires (Red), end in one central 5 Volt point, in the Power Supply.
Same for the 12 Volt power rail.
This means, for example, if you test one Orange wire, and it shows 3.3 Volts on the multimeter, the 3.3 Volt power rail is good.
Test one Red wire in a power cable. Shows 5 Volts, or VERY near?
The 5 Volt power rail is good.
Same thing for the 12 Volt power rail.
One method to check the 5 Volt power rail, and the 12 Volt power rail.
Use a 4-pin standard Peripheral power cable. (The connector on the cable is misnomered as a 'Molex' connector),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheralMost of the time there is an unused Peripheral power cable.
You can use it's Red wire, Yellow wire, and Black wire, to test for 5 Volts, and 12 Volts.
Disregard the following if you are aware;
An economical multimeter can be purchased for around $5 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog, or Digital, is fine.
The Red lead is the Positive lead. The metal tip is the probe. I refer to both as the Positive probe lead.
The Black lead is the Negative lead.
The Positive probe lead ALWAYS goes to the power wire to be tested.
3.3 Volt, or 5 Volt, or 12 Volt.
The Negative lead ALWAYS goes to Ground. (A-N-Y Black wire, is a Ground wire)
Computer sitting on a table, or workbench, computer case open, 4-pin standard Peripheral power cable, untangled, and pulled to the outside where you can access it easily, the computer is plugged into power.
The center knob in the middle of the multimeter, is the Function Knob.
It is set to DC Voltage.
If there are only symbols, the symbol is a dotted line over a solid line.
(NOT a curved line over a solid line)
If there is more than one setting for DC Voltage, set it to the 0 to 50 Volt scale.
Turn the computer on. Holding the connector in your hand, of the 4-pin Peripheral power cable, insert the Positive probe lead's tip, into the socket hole with the Red wire.
Hold the probe lead, with the hand that is already holding the connector. With the other hand, insert the Negative probe lead's tip, into the socket hole with one of the two Black wires.
Watch the multimeter. You should be reading close to 5 Volts.
Test the 12 Volt wire using this method also. (Yellow wire, and Black wire. Black wire is Ground. Either one of them)
The 3.3 Volt power rail is tested using the Orange wire, in the 24-pin ATX main power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24Power cable plugged into the motherboard, as in the photo to the right.
At the end of every wire, going into that long whitish connector with 24 socket holes, is a metal terminal.
The metal terminal is pretty far down in the socket hole. The probe lead must touch the metal terminal, but cannot due to it's size.
Use a straightened out paper clip.
The paper clip's diameter is small enough to slide into the socket hole, RIGHT NEXT TO the Orange wire, and touch the metal terminal.
Then the Positive probe lead is held against it. (Or with an alligator clip attachment, it is clipped on)
Do the same for A-N-Y of the Black wires. They are all Ground wires. Pick one. Insert a straightened out paper clip. The Negative probe lead touches it.
(Paper clips inserted, THEN computer turned on. It is only 3.3 Volts DC, but I want you to feel safe)
More in a Comment.
