Skylink Group Skylink Home Smart Center AM100 Logo
A
Anonymous Posted on Aug 02, 2013
Keep getting error message "Zone 1, sensor 1, failure" and also get "Panic" calls once a day. Replaced batteries, reprogrammed. No help!
Belzique
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 23, 2014
Belzique
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
4951
Points
10
Skylink has two lines of DIY security system, SC-100/SC-1000 and AM-100/ML-100. The remotes for the two systems, such as keychain remote or keypad remote, are interchangeable but the sensors are not 100% compatible. If the wrong sensor is used, it may still be possible to program into the system but it may operate abnormally.
From the description of the symptom, it is likely that wrong sensors are used in the AM-100 system. Check the accessories model number whether it is for SC or AM/ML system. Otherwise, make sure that only accessories from the original factory package are used.
For door/window sensor, the SC model is bulky and consists of one sensor body and two magnet pieces. The AM/ML model has one piece of magnet built into the sensor body. The other sensors are similar in appearance for SC and AM/ML model but the AM/ML sensors have the "AAA+" marking.
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
1helpful
I keep getting an error message of F1-2 or F1-1. The lower oven won't heat up and the upper oven will only heat a little. I am now geting the error message when using the stove top, but not seeing any...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
Nissan's 3003 pathfinder ,after changing suvs battery the doors lock OK and panic buttons work ,but the remote start doesn't work?
G'day mate , ussually on these latter model cars when the battery is changed you should use a small battery on little leads around 5Volts on the leads to keep the memory called the KAM ( Keep Alive Memory ) going if it has not then the computer may have lost / misplaced it , try the reprograming schedule that should be in the handbook for the remote start if it has one , hope this helps
2helpful
My thermostat displays E What does that mean?
Hi, that is the indication for "Error" and you should first replace the (2) AA batteries in the thermostat, (even if you just replaced them recently) and then using a small paperclip, reset the thermostat, by inserting the unbent end of the paperclip into the reset hole next to the keypad.
Be advised that this will reset the thermostat to the default temperature and time cycle settings, so you'll have to reprogram the unit, once you've reset it. With your unit, you only need to set a weekday setting and one for each of the weekend days.
Here's a copy of the instructions for your use in resetting and reprogramming the thermostat, once you've replaced the batteries.
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44260.pdf
You can also contact Hunter tech support, should the above info not get your thermostat back in working order by calling them at 1-888-830-1326, from 8 AM to 5 PM Central Time.
I hope you find this Very Helpful and best regards!
Battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
1helpful
2answers
3answers
Hello, I just purchased a GE SImon XT system with two motion detectors and a smoke/temperature increase detector. I live in a very small house and don't need more. Everything is hooked up and works...
Clarence,
If the problem is the Communication Failure, try to reprogram the Home Security System. The codes that you need are indicated in the user's manual. If reprogramming the Simon would not resolve the problem, try to get the master code from the manufacturer.
Reprogramming the device should resolves the issue.
1helpful
3answers
My Blackberry Curve
Device cuts off. Due to whats called battery memory Device thinks battery is spent. does not realize that it has additional capacity. This is due to recharging before battery is fully discharged ie in the red zone. Solution. install a new battery. it worked never had the problem again.
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Top Skylink Group Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Skylink Group Home Security Expert? Answer questions, earn points and help others
