Computers & Internet Logo
A
Anonymous Posted on Aug 02, 2013
Error line: unregistered - Polycom Computers & Internet
1helpful
NComputing vSpace not installed my pc Error
Options:
(A)
An authorization error usually occurs when more than one system in a LAN has the same software serial numbers assigned to the system. In this case, the first PC to be turned on does not suffer an authorization error, but any subsequent PC's which contain the same serial number will experience the issue.
To remove these duplicate serial numbers, first unregister them, then delete them from the host PC they are installed on:
  1. Access the NConsole application by either:
    • Click "Start" > "All Programs" > "NCX-2000-XP" > click on the entry labeled "NCX - 2000 - XP"
    • Double-click the NComputing console application icon in the system tray
  2. In the left-hand pane, navigate to "Local Settings" > "Information and Settings" > "Serial Numbers"
  3. To unregister a serial number, right-click on the number and select "Unregister now"
  4. To remove serials, right-click on the number and select "Delete"
Also, an update that does not install correctly may rarely cause corruption of the data file in which serial number information is contained, causing this error. If there are no other X-series hosts on the network with duplicate serials, then a complete uninstall and reinstall of the X-series software may fix this issue. When uninstalling, choose to unregister all serials and remove all serial registration data.
To download the latest version of our software, please search the knowledge base using "software download" as the search text, for links to the latest software.
(B)
When more than one X300 station is used under the same login (same Username on two or more stations), Active Desktop error messages may occur. Also stations would be sharing same user settings and other files, which could cause unpredictable errors.
Different stations should always be used with different usernames logged in. To add more User accounts (usernames), go to Windows Control Panel, select Users and then go to Create New User option.
3answers
Printartist login
Greetings,
What is the exact error message ?
Look for other links/shortcut from the Start Menu list (something like Activate)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
What do i do if the Sim card on the cell phone says Unregistered Sim what do i need to do?
My name is Bhargav
motorola v3 mobile purchase in amerika
but my home in india (gujarat - surat)
my motorola problam in not support all sim
mobile on to display error in unregister sim
please my problem soll
my contact no 9016893902
Thank You sir
2helpful
2answers
Error 2350
THE PROBLEM The Windows Error 2350 occurs when the installed version of the Windows Installer is too old for the MSI to execute. The registration entry for the engine has been damaged and all attempts to execute the MSI installation packages will not be successful.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
THE SOLUTIONTo fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver (Type both command in run) or the command line switches. The user will then have to restart Windows.
4helpful
How can i repair error 2350 with no cost?
To fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver or the command line switches. The user will then have to restart Windows
Catastrophic failure reported by operating system - Vista home pr
Try this..
START button > RUN
Type in or Copy/Paste from here into the command line...
REGSVR32 JDBOLEDB.DLL
This will try to register it. If no error messages pop up it's been added.
To unregister it do... /u
REGSVR32 /U JDBOLEDB.DLL
8helpful
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
1helpful
Missing MSIEXEC.EXE
Try this:
To unregister and re-register Windows Installer:
Click Start, and then click Run.
Type in the Open box: msiexec /unregister and then click OK.
Type in the Open box: msiexec /regserver click OK.
Beep sound
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology.
A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen..Use registered memory and it will be fine..
3answers
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
