SOURCE: It won't turn on. The battery charge light is on..
Either the charging circuit is faulty, or the battery has drained and the safety circuit has disabled it. If you have a warranty send it back, if not, take it apart and try charging the battery from an external 5v source. Do not leave it this way for more than a half hour as it will overheat and could explode.
After it's gotten a bit of a charge (if you have a voltmeter check that it's over 3.7 volts) put it back in the player and it should start up. Now try charging it the regular way. If it doesn't charge further then the charge circuit is damaged. Try a cell phone repair center, they should be able to help.
SOURCE: my archos 7 wont charge the red light comes on but
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
SOURCE: archos charging the battery takes too long
I found that I have to leave my archos 605 powered on to get a full charge out of it, blinking light and all
