You should have a micro HDMI port on the tablet. You need an adapter that goes from micro HDMI to regular size HDMI, then an HDMI cable to your TV. Change the TV input to HDMI and you should be fine for video and sound.
• Micro USB 2.0: Mobile Transfer Protocol (MTP)
• USB host via OTG
• microSD (compatible with 64 GB cards)
• HDMI output (Mini HDMI / HDMI cable sold separately) If you have the Mini HDMI to HDMI cable you may be able to connect to HDMI input of TV, or try USB out of the device to Computer input on the TV....
I have the same problem. No sound at all on my Archos Cobalt 80 tablet. Hasn't been dropped, bumped; just suddenly stopped working. Tablet has been formatted, soft and hard reset, backed up and restored to factory default settings, updated the firmware and still no sound. Any help is appreciated thanks.
very small scew under kick stand two more under feed opposet of kickstand screw driver catch latch left and right sides of achos logo pop open plug and play hope that helps :)
ooooh one more thing beware the only thing holding the usb port in is the screen it may slide out of place when you open the tablet its not supposed to be opened and is a little tricky to line up when your closing it again.
finaly only do this if the warntee is up archos will replace the internal batter for free if it is still under warantee
finaly the archos 101 battery also fits the 80g9 but very snugg it will however give you just shy of 48 hours constant use over the 15 hours that the 80g9 original battery will i had mine playing a 80 hours youtube play list for two days before it lost power and did not plug it in just to see how long it lasted roughly 53 hours i think
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output".
2. Then start playing a movie on the archos.
3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV.
4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
