Question about Vivitar ViviCam 5150s Digital Camera
Vivitar 5150s Digital Camera. Option to set date and time does not appear on menu>setup list(?). No help in manual.
  • Pete Richards Aug 02, 2013
    Thank you to kakima for your response. However, I am not trying to print my pictures, simply to store them on my external hard drive with folder names that index the date/time taken. When you right-click the picture thumbnail in Windows Explorer to access the Properties tabs the only date attached to any pictures appears to be 1 January 2006 (?).
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Posted on Aug 02, 2013
Testimonial: "Please see comment above"
SOURCE:
SOURCE: vivitar 3720 digital camera
,,,push the "square" button in the middle of the direction arrows.
..press the right arrow across untill you come to Date and Time
...press the down arrow to select the "set" and press the square button again
....use the up and down arrows to select the correct date
....use the right arrow button to set the month and day and so on.....
Also, if you don't want the time displayed on the picture, just select "no display".
I hope this helps!
Posted on Feb 08, 2008
SOURCE: HELP! Getting the date/time stamp off your Vivitar 5100...
When you turn on your camera, press the menu button. That will bring up the screen that has the orange buttons at the top (Capture) (Setup) arrow down using the buttons on the far right side. The down button will be the dame button that you use to delete pictures with. When you get to the botton of the page continue arrowing down and that will bring up another page. Arrow down until you get to the botton there are only 3 items on this page and the bottom item will say the following:
Date imprint ON
Press your enter button (ok button) and up will pop ON or OFF.
Arrown down to the OFF and press enter and that will remove the date imprint from your pictures.
Hope this helps you.
Posted on Sep 21, 2008
  • 94 Answers
SOURCE: How do I turn off the date option?
Go to the Capture Menu. In the Capture menu, you can determine the conditions you would like to choose such as Size, Quality, Scene, EV, White Balance, ISO, Color, Saturation, Sharpness and Date Imprint. Press the MENU button and then scroll through the options. Choose "Date Imprint" option and then change it to OFF so that the Date will not be showed on the captured image. If you want the manual just download it from this site "http://www.retrevo.com/support/Vivitar-5100-Digital-Cameras-manual/id/200bh832/t/2/". Hope it helps.
Posted on May 31, 2009
  • 102366 Answers
SOURCE: Cannot set the date on Vivitar Vivicam F328.
Press the HOME button to bring up the main menu. Touch the pliers-and-screwdriver icon function area to enter the Setup menu. Touch the down-arrow function area repeatedly until "Date" appears. Touch the calendar function area to enter the Date menu.
Posted on Feb 24, 2011
  • 102366 Answers
SOURCE: how do i set the
Press the MENU button. Press left/right to select the wrench icon. Press up/down to select "Date" and press the MENU button. Use left/right to move between the fields, up/down to change them. Press MENU when done.
Posted on Mar 03, 2011
Testimonial: "thankyou but I'd managed to do it before you got back to me but thanks anyway"
How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
  • Press the Up or Down buttons to select the Date option in the Setup menu.
  • Press the OK MENU button.
  • Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
  • Press the Up or Down button to enter the Set Date option.
  • Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
  • Press the Up or Down button to set the Date and Time digits.
  • Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
  • Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
May 16, 2011 | Vivitar Vivicam 8225 Digital Camera
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
I do not know how to change the date on the camera. Con you help me
Press the Home button to bring up the main menu. Touch the Setup function area (pliers and screwdriver) to bring up the Setup menu. Touch the down-arrow function area until you see the "Date" option. Touch the calendar function area to enter the Date menu. Select "Set date" and press MENU/OK. Use left/right to select a digit and up/down to change it. Press MENU/OK when done.
See page 22 in the manual.
Mar 06, 2011 | Vivitar ViviCam 8025 Digital Camera
HOW DO YOU GET THE TIME & DATE ON A PHOTO
Press the HOME button to bring up the menu. Touch the Setup icon (pliers and screwdriver icon) to bring up the setup menu. Touch the down-arrow icon until the "Date" option appears, then touch the function area to bring up the date menu. Touch the left-arrow function area to select "On". Press the Menu/OK button to confirm.
Feb 12, 2011 | Vivitar ViviCam 8025 Digital Camera
How do i change the language to english
I suggtes the ViviCam_8225_Camera_Manual
You can adjust the way your camera is setup with 11 setup option: Exposure, ISO, White Balance, Sharpness, Quality, Date, Auto Power off, Frequency, Language, Copy, Format and Default Setting.
1. Press OK in MENU button.
2. Press the Right/Left button to select the right icon.
3. The Setup menu appears in the center of the LCD.
4. Press the Up/Down button to select one of the setup submenu options.
Additional details directly from Email: support@vivitar.com
Or Phone US: 1-800-592-9541
UK: 0-800-917-4831
Australia: 1-800-006-614
Hope helps.
Feb 03, 2011 | Vivitar Vivicam 8225 Digital Camera
Jun 16, 2010 | Vivitar VIVICAM 7388 Digital Camera
How do I reset time and date on vivitar vivicam5150s
ask here for the manual:
http://manualfox.com/link/vivitar.htm
May 17, 2010 | Vivitar ViviCam 5150s Digital Camera
How in gods name to i change the date on this thing so its the right one please
Press the HOME button. Touch the Setup icon (the wrench and screwdriver). Touch the downarrow function area until the "Date" option (desk calendar) appears. Touch that to enter the Date menu. Touch the leftarrow function area to select Set Date and press the Menu/OK button to confirm. Touch left/right to select the digit and touch up/down to change it. Press Menu/OK to save your changes.
It's all in the manual. If you've misplaced yours, you can download a new one from the manufacturer's web site at http://vivitar.com
May 16, 2010 | Vivitar ViviCam 8025 Digital Camera
I need to set the time and date on my mums Vivitar Vivicam 8018 and can't work out how to do it! Any help appreciated (Or we're 99 weeks behind real time forever more!)
1. Press the Menu button to enter Set Date option.
2. Press Left/Right to scroll from one option to another.
3. Use Up/Down to change the highlighted digits.
4. Press the Menu button to confirm and save.
This is on page 21 of the manual.
Jan 27, 2010 | Vivitar ViviCam 8018 Digital Camera
Vivitar ViviCam 5150s Digital Camera Logo
57 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
