SOURCE: memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
SOURCE: memory card
Hi Aisha,
I had the same problem but and i checked the small tab on the side of the card. it was in unlock position. i subsequently fixed the card adaptor to rest firmly on the side of the switch using a small paper wedge on the opposite side. This cleared the problem. However card adaptor should now not be removed otherwise you may revert to original problem
Regards,
Luwangula
SOURCE: My samsung camera L313, Keep saying card Locked
SOURCE: My samsung TL150 says "card locked". How do I
Take out the memory card, flip the little switch on the side from locked to unlock. Then reinsert it and try it then.
