When dishwasher is started, it cycles through to empty any standing water, then refills with new water. Instead of going into the wash cycle, it starts making a chirping noise (sounds like a cricket or small frog) - appears to be coming from the bottom of the dishwasher. This unit is about 1&1/2 years old. Cannot find any debris/utensils blocking anything. There are 5 different modes of wash that can be selected. This problem occurs on all modes.
Allan
Same Problem, but need a better answer - tried all I can think of -
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
