When TV is turned on, picture appears for 2 seconds then dissappears.
Symptoms like 2 seconds picture then disappear shows problem in Back Light Inverter board of your LCD2060 TV and back light inverter board requires replacement.
Akai Customer Support is no where on earth and it is very hard to find parts for Akai products.
Click Shop Jimmy and call them for back light inverter board of LC2060. If subject board is available then fine otherwise new LCD TV of another brand would be good option.
Hit "add a comment" button if you have any question.
Thank you.
Connect your allconnectrion to television again.
Also check your power supply and earhing proper working.
Reset all settings to factory defaults.
connect your allconnectrion to television again. - WHAT IS ALLCONNECTRION?
Also check your power supply and earhing proper working. - TV TURNS ON & PICTURE APPEARS BRIEFLY SO POWER SUPPY SHOULD BE FINE. WHAT IS EARHING?
Reset all settings to factory defaults. - HOW CAN I RESET DEFAULTS IF NO PICTURE - IS IT DONE BY REMOTE? WHAT REMOTE KEYS DO I PRESS TO RESET?
I have a Akai 2060 TV. When I turn on TV I get a picture for 2 seconds, then screen goes blank. I have sound but not picture. Is there are remote setting to fix this? please advise.
