GE Profile JGBP79 Gas Kitchen Range Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"door" appears when selecting bake or broil.
When I try to bake or broil on my GE profile range, the code "door" comes on. I have ran the self-cleaning feature and this still happens. How can I fix this?
Anonymous
Level 3:
  • GE Master 3,361 Answers
  • Posted on Apr 02, 2009
Anonymous
GE Master
Level 3:
Answers
3361
Questions
Helped
1029912
Points
10654
First take the door latch lever and push it to the left with moderate force. This may re-align the switches inside. If that does not correct the problem replace the door latch switch.
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
7helpful
4answers
Lost instructions - I have my oven cleaning how
Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
1helpful
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
1helpful
MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
22helpful
5answers
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! [email protected]
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
