Uniden Cordless Phone Logo
Posted on Jan 13, 2018
GE Model 28112 Dect 6.0 Cordless phone makes high pitch noises
All of a sudden my phones do not work, They make a high pitch screaming noise when I turn them on or try to answer a call with them. I also cannot dial out on them. I keep them charged so not sure what the problem is. I cannot find anything in the manual that covers this. Any help would be appreciated
5 Related Answers
poohbear80
  • Posted on Feb 28, 2008
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
phones say do not disturb and will not ring
Anonymous
  • Posted on Apr 03, 2008
SOURCE: ge cordless Model 28112 6.0
I found out that I needed to puch the program button. the manual was not clear on this.
Thanks
Anonymous
  • Posted on May 30, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Anonymous
  • 39 Answers
  • Posted on Mar 20, 2009
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
consultel1
george peters
  • 860 Answers
  • Posted on Dec 21, 2009
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
GE cordless phone beeps in slient mode when someone calls
hi Mcbain,
try the hand set leave some time (30 min) by remooving battery.
try again.
let us inform the results.
regards.
nuwan
1helpful
Need an instruction mnual for GE 28112EE3-A Dect 6.0
Thomson built the 28112 Expandable DECT 6.0 phone for GE. They have the manual available on their support site: http://www.home-electronics.net/user_guides.asp . The direct link to the manual is http://www.home-electronics.net/USER-GUIDES/28112_DOM_EN_CL_IB.pdf .
I hope this helps.
Suddenly making loud static noise
I have a dect 6.0 cordless phone and all of a sudden it started making this very loud, high pitched continuous whisltling sound. It only stopped when I took the batteries out. After putting them in the phone seems fine now.
Any ideas what happened?
1helpful
Need instructions to reset time on our GE DECT 6.0 cordless phone
You know how MANY Dect 6.0 cordless phones G.E. makes?
Here is a link to GE, look for the model number on the bottom of the phone.
And search for it, or look at the pictures and click on the picture of your phone... then after that near the middle of the page slightly to the left there is a Bloue Box - Product Instruction Book - English... press this to get your manual.
http://www.home-electronics.net/ge/pc/showsearchresults.asp?pageStyle=H&resultCnt=10&keyword=dect+6
Good Luck!
Phone noise
get a new cord the one from head set 2 phone.
Ge cordless Model 28112 6.0
Thanks
4helpful
6answers
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Inaudible announcement
How close were you to the base unit when you recorded the message? The manual suggests 9 inches from your mouth to the mic on the unit. Also speak loudly when you make the recording. Yes, you can re-record the message. In fact, you can record two messages and use whichever one fits your immediate circumstances.
2answers
Ge model 28112 dect 6.0
I had the same problem. In my case my telephone co. told me to dial #55 then my code. Try reading your telephone co. instructions on how to retrieve messages. (not the instructions which came with your GE phone.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
