Question about Razor MX650 Electric DirtBike
Engine is not working - Razor MX650 Electric DirtBike
Hi I have a VZ 2005 Adventra AWD 3.6lt v6 Engine code H7C I hade engine changed I think they put a VE 2009 3.6 engine the local Holden dealer can't start it sensors don't match so cam angles
Only answer i can give is fit correct engine. Some engines are not compatible to modules fitted to vehicle and cannot be reprogramed. If a Holden dealer fitted this engine they should be aware what engine works or doesn't work. Good Luck
May 07, 2017 | Holden Cars & Trucks
Will the engine from a 1999 jeep grand cherokee work in a 2004 jeep grand cherokee / INTAKE connections and all
what engine, we cant guess them ever
vin code?
engine photo.?
displacement.?
what?
long block plus, the whole thing, well that means what?
all sensors working and injectors too?
why not just pretend to buy a rebuilt engine at say anywhere
real store or web store, online, google works
buy jeep rebuilt engine, try that , it works every time.
and they show the range of engine that work
or at the wrecking yard they can too..
Jan 25, 2017 | Jeep Grand Cherokee Cars & Trucks
How does my engine brake work?
Engine brakes or Jacobs brake on diesel engines work by using engine oil pressure controlled by a electric solenoid in three stages, the oil pressure is directed to a piston which holds down an exhaust valve slightly approx 2.85-3.5mm.
The three stages of exhaust brake on a six cilinder engine activates two cylinders at a time, cylinders 1-2 stage one, cylinders 1-2-3-4 stage two, and 1-2-3-4-5-6 stage three.
A Volvo engine brass or VEB works kind of the same only it uses a separate lobe on the camshaft to open the valve for engine braking...
Hope this helps..
Feb 05, 2016 | 2013 Suzuki Grand Vitara
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
I have 16 hp Kohler engine with a compression release not working,help.
i have a Kohler 16 Magnum opposed cylinder engine and it wont crank over with the spark plugs in it,battery and starter are both good,its an aluminum engine and i have seen several of the Kohler engines break the automatic compression release on the cam gear and they seem to lock up while trying to start,pull the plugs and the crank fine,Kokler is the most expensive engine i have seen and their parts are outrageously priced,old Kokler was a good engine,newer ones in my opinion are junk,i work at a small engine shop,i have seen new Kohler engines with a broken ACRs,i work at a second job,we got a new supervisor that worked for Kohler before her came to our plant,he said he worked customer service at Kohler and he heard complaints constantly from people using their engines and the returns were out the roof on their engines,what im saying is i wont ever but another Kohler unless itsm an old one,Thanks Tommy
Jun 06, 2012 | Kohler Electrical Supplies
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
ALTERNATOR REPLACED WORKING OK NOW TIMING BELT PETROL AND BATTERY WARNING LIGHTS ON WHEN ENGINE RUNNING AND A/CON NOT WORKING
If your battery warning light is on, then your alternator is NOT working okay. Rather, maybe the alternator DOES work, but the battery light can also come on if your battery won't charge.
Put a voltmeter to the battery terminals when the engine is running and rev the engine to a medium idle. Battery charging, (engine running) it should be about 13.5-14.5 volts. Engine off fully charged battery voltage should be 12.6 volts.
Quick test-engine running, disconnect the positive battery terminal from the battery- if the engine dies, there is still an alternator problem.
Hope this helps.
Mar 15, 2010 | 1993 Isuzu Trooper
2007 Chevy Silverado when my check engine light comes on remote start won't work after a couple days check engine light goes off remote starter works?
It's a safety feature. For example, if there is no oil pressure when you start the engine, you could not see that unless you were in the car and could spin a bearing or seize the engine by starting it remotely and letting it run unattended. So when the check engine light is on, there is something not working properly with the engine/engine management system and it wants you in the car where you can see the guages and turn the engine off immediately if there's a serious problem.
Jan 05, 2010 | 2007 Chevrolet Silverado Classic SS New...
Engine replacement - distributor vs. coil pack - 97 Tacoma 2.7L
ok, try to put all accesories from your old engine to used engine, toyota dont make conversion kit, and the distribuitor is not compatible with your wires
Apr 13, 2009 | Toyota Tacoma Cars & Trucks
Razor MX650 Electric DirtBike Logo
53 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
