The printer has a cutter attached to it. I cannot get the cutter to cut labels. Any suggestions?
Cutter will work manually but not from a spool file.
Printer has Media set to 'Cutter'.
Label print options sent to printer are listed below:
Printer: Z140XI ZEBRA 140XI THERMAL
Number of labels per set................. 0001
Spool file processing (N=Normal D=Demand) D
Print Quality:
Print Speed Option............(2-9 J-L).. 6
Thermal Setting................. (01-60). 30
Media:
Labels: Continuous=0 InterLabel Gap=1 1
Black Stripe=2
Ribbon: No ribbon=0 Thermal Transfer=1.. 1
Dispensing:
Peeloff=P Tearoff=T Normal=N Cutter=C. C
Cutter:
Cut labels at end of each set......(Y,N). N
-or- Cut Interval............(000-099). 001
Print Density: Dots Per Inch........(100,203). 20
Print Exact Qty (slower)................(Y,N)
Make Smooth: (change to vector)
0=Keep as is 1=All Fonts 2=Only Non-Native. 2
Serialization: Process on the printer...(Y,N). N
Memory Allocation for Cache: 0=No Cache (0-9). 0
SYMBOL SET: ............................(1-Z).
Rotate label: UpsideDown=3 Normal=1........... 1
Global print position adjustment:
Move all print Forward(+) Backward(-)...... +
(0-064)..... 000
Form Size:
Form length ....................(inches). 01
(fraction). 1
(LPI 6,8). 8
Form Length in DOTS...................... 00227
Form Width(in 10ths)..................... 041
HORIZONTAL GAP ADJ IN DOTS............... 000
Number of labels ACROSS.................. 01
Miscellaneous
USE PREVIOUS RELEASE PROGRAM........(Name)
USE GRAPHICAL INTERFACE ADJUSTMENTS..(Y,N) Y
