Havent started my fzr1000 in five years. any suggestions?
Change the oil first up as their is a good chance condensation has occurred and put water in to the oil. Drain the fuel from both the tank and carburettor, as this would have gone stale. Change battery or jump start if required. Remove the spark plugs and inspect, replace if looks suspect. With the spark plugs out, crank the engine over a few times. (ensure oil level correct) If it winds over all good, put a few drops off oil in the cylinders. This will help build compression. Re-fit spark plugs, Full choke and give it a shot. Away it should go! Aerostart or ether may come in handy.
