Question about La Crosse XG-55 Wrist Watch
Changed battewry , dots blnk ,what next - La Crosse XG-55 Wrist Watch
Changed battery on Accurist BJ3547 as hands stopped though digital signal was still OK. New battery installed, digital signal still OK but hands still don't move . A video said a reset req'd, How?
  1. The "AC "or "All Clear Circuit" button if the watch has one will be found on the back of the movement. It will usually be a small silver or gold dot marked "AC" or reset. In some cases it will be a small hole or plunger you depress with a pin punch.
  2. Clear watch memory. Look for and find the small gold or silver dot on the back of the Seiko watches movement. It will be marked "AC" if it exists. Use the metal tweezers and touch the "AC" button with one prong and the battery with the other. In some cases you just push in the plunger on the "AC" button. In the case of a plunger or hole press it with a pin punch.
Aug 14, 2016 | Accurist Watches
Reset alarm stopwatch start pc396 pressing hourly chime
with the alarm time showing - press the split reset button if the hourly chime is on you will see a row of dots above it. Press the mode button to get the dots to disappear and turn off the chime.
Jul 16, 2013 | Fossil Watch Style # FS4387
Blue dots on black images
I can tell you that I had my plasma screen replaced in the 4th year. The tech told me that the replacement panel was much more reliable. You may be looking at replacing the plasma panel...(which may be more expensive than replacing the whole unit??).
Jan 29, 2013 | Samsung HP-S4253 42-Inch Plasma HDTV
How do I set the time on a philippe starck ph1110? There aren't any buttons to push...
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker
Dec 30, 2011 | Watches
Submariner-how do I open it? I dropped it, and one of the dots(#'s) dislodged on the face.
If it is a true Rolex they require a special wrench that grips the tiny serrations around the base of the back. You will need to take it to a watch repairman, the tool is very costly.
Feb 13, 2011 | Rolex Oyster Perpetual Submariner Date...
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Aug 31, 2010 | Timex Watches
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
I have a Fossil JR8103 woman watch with leather strap and the face of watch is held on by two silver dots. I can't figure out how to get the face off so I can change the battery. Help!
DONT try to change a watch battery yourself unless you have crystal press to close it and thats if the case back pops off...if it screws on then you need a case wrench to open and close it! Better to seek out a local watch repair business and avoid Walmart! :-P They arent trained to repair watches...Ive fixed a lot of their mistakes!
Aug 09, 2008 | Fossil Watches
Adidas watch ADP 1112
change the battery for that... its showing errors which means that needs a new battewry.
Apr 12, 2008 | Adidas Digi III Watch
La Crosse XG-55 Wrist Watch Logo
48 people viewed this question
Top La Crosse Watches Experts
Arturs Kalnins
Arturs Kalnins
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
