Question about HP Compaq nc6120 Notebook
Used Easy Drive Lock .. but it do not unlocks my drive
I ve used Easy Drive Lock .. it locked my drives and on ulocking its show the ms " Unlock Succedded" but it doesn't unlocks it ..
Seek urgent help... kindly someone help me out..!!
    Guru:
  • HP Master
  • 829 Answers
Uninstall the Easy Drive Lock Driver.
Posted on Apr 02, 2009
  • 2 more comments
  • Milind Shetti
    Milind Shetti Dec 29, 2009
    Hi
    However, there might be a problem with the shared resources. While
    testing the program I learned that any locked partitions can be
    accessed, if you enter the full path of an item (file or folder) into
    Windows Explorer. So much for protection. A locked partition can be
    accessed either locally or by using a remote machine this way.
  • Milind Shetti
    Hi
    + This is my way I used to unlock:
    How Do I Get the Security tab in Folder Properties?
    First, your hard drive must be formatted NTFS for this tab to show up.
    Second, if you're running XP Pro, you must open Windows Explorer, go to Tools, Folder Options, View and uncheck Use Simple File Sharing.
    Third, if you're running XP Home, Simple File Sharing is enforced
    by default and cannot be disabled. You must boot the computer into Safe
    Mode and log
    in with the Administrator account, in order to see the Security tab. A
    work around for XP Home, so that you don't have to enter Safe Mode, can
    be found here.
    + After three steps you'll get security tab in Driver properties.
    My system had no tab edit permissions appeared in the first, but after
    ten minutes, it had appeared. -> Good luck to everybody, we need
    saygoodbye to "easy drive lock program".
  • rahma fauziyah
    rahma fauziyah Jan 25, 2014
    how to get the "security" tab in windows 7? I am very dizzy to find the security tab...because in here not found..please help meee...:(
  • rahma fauziyah
    how to unlock my drive if I use windows 7? my drive is locked by "easy drive lock software" and very difficult to unlock it..please help mee :( thanks
6ya staff
SOURCE:
How to unlock my local drive if it was locked by "easy drive lock software"??
To unlock the hard drive unlock x:
The x represents the letter of the hard drive that you want to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
To lock the hard drive lock x:
The x represents the letter of the hard drive that you want to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jan 25, 2014 | Computers & Internet
Sun locked
You need to unlock the carrier lock of Nokia Classic 2700 in order to use it with other network Sim cards . To unlock the carrier lock you can use unlock code. To get the unlock code visit WickedUnlock.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your phone.
Jul 20, 2013 | Nokia Classic 2700 Cell Phone
How do I unlock a hdd-hss password
If you are talking about a Hard Drive Password that you want to unlock, you are up the creek without a paddle. 99% of the time if there is a lock on the Hard Drive the laptop is stolen. The original owner set it to keep thieves from getting to sensitive data. The only way to unlock it is to have the person that locked it put the password in, otherwise the computer is useless. There is absolutely no way to use it with a lock on the hard drive, even if you take the hard drive out, the drive can never be used.
Apr 06, 2012 | Toshiba Computers & Internet
I have a 2003 PT LImited. The door locks intermittantly lock-unlock lock-ulock, lock-unlock several times regardless of speed, it happens while idling, driving forward, and backing up. About a year ago...
The RKEM (remote keyless entry module) is the problem.
Only a DRB-III scanner can program the transmitter codes and VIN number to remedy this problem....I hope this helps.
Aug 19, 2011 | 2003 Chrysler PT Cruiser
BAD DISK BECAUSE PASSWORD LOUCK
Issue How to lock / unlock the hard disk drive.
Cause
A hard disk drive may be come locked or unlocked allowing or not allowing for software to have direct disk access. You may encounter an error indicating to unlock the hard disk drive in any of the below circumstances.
  1. Attempting to install another operating system.
  2. Attempting to fdisk the hard drive.
  3. Installing software.
Solutions
To unlock the hard disk drive
unlock x:
The x represents the letter of the hard disk drive that you wish to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
Additional information about the lock and unlock command can be found on our Lock / Unlock page.
To lock the hard disk drive
lock x:
The x represents the letter of the hard disk drive that you wish to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jun 16, 2011 | HP Computers & Internet
How to unlock it
Hi
The HDD is locked when its in use usually. The LOCK command blocks direct access by programs that can corrupt file names and/or destroy disk data, resulting in the loss of files on your disk, Windows has one that is perfectly adequate and suited for it.
-Go to Start>Run>type: chkdsk /r and hit enter.
-You will be prompted and choose Y and reboot.
-It will run on restart and do all the necessary checks/repairs needed tp your HDD.
On a side note, in Command Prompt this is how to lock unlock a drive.
LOCK [drive:]
Hit enter and choose Y. Its locked now. For instance drive C: would be:
LOCK C:
For unlocking
UNLOCK [drive:]
The same as before, you would type unlock followed by drive location.
hope this helps
John
Apr 24, 2011 | Computers & Internet
My pen drive has become write protected and now I want to remove write protection from my pen drive,please help me.
Hi Sir.
Please look carefully at your usb pen-drive to see if there is a small switch on there somewhere that is used to lock and unlock the drive. perhaps you may have accidentally put it in the lock position.
If there is a laser pointer on the drive then using the laser pointer may have caused you to accidentally switch to the write protected mode. most drives have a lock/unlock switch on the pen-drive itself...unless it has a program installed on the drive that has encrypted and locked the drives read/write ability. Please let me know if you have success.
Thank you!
Dec 03, 2010 | Generic Memory USB 2.0 128MB Black Pen...
I replaced my broken C: drive with a new WD 3200. The computer named it J: Before I replaced it I got the old drive working and made an image of it using ReflectPE. I want to restore some of the stuff...
thru MS-DOS
1. run CMD
unlock x:
hope this works for you
God bless!
Nov 28, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Pen drive shows device is write protected while formatting. So please give me solution so that I can format the Pen drive & use it again. Kingston Pen drive with 4 GB capacity. Using Windows XP...
if you see your pen drive properly you will find a lock that you need to switch to other side for unlock device
this lock make device write protected
hope it helped you
Sep 30, 2009 | Electronics - Others
HP Compaq nc6120 Notebook Logo
330 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
