Question about Frigidaire Kitchen Ranges
Frigidaire electric range es530 i have Er on my front right burner it will not come on at all.
  • Official Brand Answer
  • 4,342 Answers
Hi Shawna, thank you for your question! ER is commonly refers to a generic error. You may try and reset the range by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Posted on Aug 02, 2013
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
  • 184 Answers
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
Posted on Apr 04, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
NEED CONTROL KNOB FOR BURNER ON MODEL ES530-L
Most knobs are interchangeable sometimes even a simple barbecue knob will fit your cooker ( it may look different) but wii still perform , pull it off and go shopping with it .
Apr 10, 2014 | Frigidaire Kitchen Ranges
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
I just replaced the right rear burner receptacle on my Frigidaire Range...mod. # FEF352AWC and now the right rear element is intermittent except when the front right burner is on
Hi - it sounds like that there is a loose wire somewhere, have another look - perhaps in the process a connection may have come loose or broke off without you noticing.
I would lean towards a bad neutral or a common loop between the elements..
Cheers
Jul 07, 2011 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
My PLEFMZ99GC is showing an
Please read this article... it appears our model is under recall by Fridgidaire. You should probably contact the manufacturer right away to see what should be done...
http://www.appliance.net/2009/recallfrigidaire-and-kenmore-smoothtop-electric-ranges-due-to-fire-hazard-1369
Oct 25, 2009 | Frigidaire PLEFMZ99GC Electric Range
Left Front and Right Rear burner does not heat up
Both burners should be replaced as well as the recepticles that it plugs into. There are recepticle kits available for this repair.
Jan 11, 2009 | Frigidaire FEF352 Electric Kitchen Range
Oct 14, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
410 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
