Washing machine shakes excessively during spin cycle
Excessive shaking and knocking from the washing machine during spin cycle. Checked load for balance and was fine. It happens almost every load now. Disassembled and removed sheet metal covers and find nothing wrong! No broken springs or brackets. The wear pads under the drum all look ok. Thanks for any suggestions.
  • Anonymous Apr 04, 2009
    mine does the same thing, wakes me up at night, soo loud
Change the three wear pads
Posted on May 20, 2009
SOURCE:
Knocking during wash and spin cycle
I woulds let a repairman look at your machine. Your rubber dampers are broken and your machine will shake itself to bits if you don't address this problem.
Mar 07, 2014 | Computers & Internet
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Frigidaire Front Load Washer and dryer shakes a lot
hi, Try a smaller lighter load, you may be filling it up with too much washing, if you still get excessive movement check your filter is not partially blocked, this could cause vibration by too much water being in the machine during its spin cycle, other than that it could be that the machines hydrolic dampers are worn or have lost thier compression and new dampers would be needed in this case.
Another consideration would be the tub bearings could need replacement, check for up and down movement by gently but firmly pushing up and down on the rim of the stainless steel tub, if movement can be felt then perhaps get them checked and replaced.
Hope this helps.
Feb 13, 2011 | Frigidaire ATF6000ES Front Load Washer
Excesive Shaking during spin cycle
Your washer has self adjusting rear legs . Tilt the machine foreward and look at the back legs . If one is stuck in , use a screwdrive and pry it out till both legs are in the out position . Set washer back down slowly and the rear legs will automatically adjust .
May 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Excessive shaking during spin final cycle
check to see if the floor is solid and not soft, thin or flexible. are the leveling legs tight? make sure the locking nut is tight and that the leg does not wobble.
Dec 23, 2009 | Maytag Washing Machines
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
752 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
