JVC RV-B550 Cassette/CD Boombox Logo
Joe Bananas Posted on Aug 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVC RV-B550 Cassette/CD Boombox Hi there. Please
JVC RV-B550 Cassette/CD Boombox Hi there. Please can anyone tell me how to open this unit? With the two halves slightly apart, I can see that there is at least one ribbon cable under stress (coming from the top cd? board) stopping it coming apart completely. I've found a service manual with schematics and PCBs, but no instructions on correctly opening it up. Thanks in advance for any advice on this. Joe.
Jim Goldsmith
Level 3:
  • Master 2,005 Answers
  • Posted on Oct 31, 2013
Jim Goldsmith
Master
Level 3:
Answers
2005
Questions
Helped
736285
Points
6152
Take off all the knobs and it should come apart
2 Related Answers
stynger007
  • 33 Answers
  • Posted on Aug 18, 2009
SOURCE: jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
gopakumarg43
  • 76851 Answers
  • Posted on Jun 07, 2012
SOURCE: My JVC rv-dp100 Kaboom boombox always has the radio or static from the radio playing. When I try to use the cd player, I hear both at the same time and cant stop it. Please help!
The fault is with its input selection circuit. Seek tech support. Might be an IC fault.
JVC RV-DP100BK orange backlit illuminate LCD display stop working?
You need a new bulb installed - difficulty is semi hard , in that you must take apart the boombox , remove the shroud around the bulb , unsolder , resolder new one ..take the old one to an electronics shop to match.
How many watt (power) is this?
  • 24 Watts Total Power
  • Active Clear Sound (ACS) to improve clarity for better balance with deep lows
  • AUX Input
  • 3 Preset Equalization Settings
  • Digital Tuner with Auto Preset
  • 15 AM and 30 FM Station Memory
  • Twist Lock CD and Cassette Doors
  • 1-bit D/A Converter
  • Continuous, Repeat, and Random Play
  • Programmable up to 20 tracks
  • Auto-Reverse Cassette Transport
  • Full-Logic Tape Control
  • CD Synchro-Start Recording
  • 2- 4" Full-Range Speakers
  • 4-Layer Voice Coil: shifts down the lowest resonance frequency and increases driving power
  • Long Labyrinth Ducts: extend the frequency response down to the lowest frequencies
  • Speaker Illumination: the illuminated center cap blinks with the rhythm of the music
  • Carrying Strap with Remote Control Holder
  • COMPU PLAY
  • Clock/Timer with Sleep and Wake-up
  • Back-lit Illuminated LCD Display
  • Full Function Remote Control
  • 1 Year Parts and Labor Warranty
  • Weight: 13.5 lbs.
  • Width: 21 3/8"
  • Height: 8 9/16"
  • Depth: 10 1/4"
  • 0helpful
    1helpful
    The tape motor on my JVC-B550 no longer functions. Is this fixable?
    It is qquite possible to fix this. It may not be the motor either. Without seeing the actual unit, I can not state for sure, but quite often it is the belts that are bad. If it is the motor, look on it for some numbers. I don't think that JVC uses Mabuchi motors, but they may. These are generically available and cheap. Post any numbers that are on the motor and I'll look for a source for you.
    Dan
    8helpful
    2answers
    WHERE CAN I BUY A JVC RV-B550 IN NEW ZEALAND
    You may be able to find one at http://www.trademe.co.nz
    there are at least 1 or more there, just looked
    1helpful
    3answers
    JVC boombox RV-NB 1 stopped working
    Its the fuse (1.25A 250V slow blow) remove 12 allen screws on side panels, six each side (the very top and bottom allens are
    for comestics) remove the woofer screws (just the two of the four)
    that are facing the front panel.remove the 12 screws in the rear panel. 6 along the top, 4 along the bottom, 2 in the middle.
    go to Radio Shack, Get a 2A 250V slow blow fuse (they dont have a 1.25A) Part# 270-1064 (4-pk about $3.00) reinstall & ROCK !!!!
    Cant close CD Lid.
    Contact customer support at JVC America,they will help you there
    2helpful
    Jvc rv-b99 cassette door jammed
    1helpful
    Bulb illuminating lcd display panel failed
    go to an electronics store. You need a 12 volt bulb that solders onto a small removable circuit board located directly behind the display.
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
