Question about Tablets & eReaders
Hi I just got a tablet online and it doesn't have
  • 1 more comment
  • Anonymous Mar 15, 2014
    i was searching on playstore to dowbload instagram BBM and then they post "Your device isn't compitable with this version
  • Anonymous Mar 20, 2014
    My tablet just reset itself and now all my apps and pictures are gone and everything else..how do I get it back to the way it was? Please help
    My prestigo tablet just reset itself and now all my pictures and apps and everything I had before is gone!! Please help
    New Friend:
  • 21 Answers
Just make sure with the play store settings, whether you have sign in with your G mail account or not. If no just sign in and try else register as a new user and try. If found still there were an error. Just try to restore the tablet. If you again found the same error then, shutdown the tablet and press power + volume up button up to 15 seconds, so that you will get restore option there and restore through that. Definitely it will work for you.
Posted on Aug 01, 2013
3 Suggested Answers
SOURCE:
appdevices
SOURCE: i have a polaroid android tablet. it one day just started to not work anymore.
Just a thought, however, it might be that it automatically upgraded your Android operating system and now the apps are not compatible. Try deleting one of the apps and re-installing it. Hope this helps you - Learning Thermostat
Posted on Nov 19, 2012
  • 54 Answers
SOURCE: my daughter forgot her unlock pattern for her craig 7' android tablet, how do we factory reset
press and hold the camera button and the on/off button at the same time.
Posted on Jan 04, 2013
My tablet when turned on it gets stuck in android and doesn't want continue. I had searched and I need the rom update and I Don't find it
This is a duplicate of this post: My tablet when turned on it gets stuck in android and doesn want continue...
The same answer applies. Contact the manufacturer or check their support page.
Jul 10, 2015 | Tablets & eReaders
Hi I am locked out of my hips street flare tablet , I recovered my password but it still doesn't accept it, help
Go into setup and rest to factory settings and start over should be in the settings part of tablet
Feb 21, 2013 | Tablets & eReaders
Coby Kyros 7" tablet location of the IMEI ?
You mean the MEID and UICC ID. Usually you can see this under settings
Go into Settings > About / About Tablet
This may or may not be the case with your tablet I would check there first. Otherwise I believe it requires some disassembly to access the battery.
Dec 05, 2012 | Coby Kyros Android Tablet
Key clicks is ON , but NO sound
Is it possible that you also changed the function of the lock switch?
Try going into settings and change the settings of the lock switch to mute/unmute then place the switch itself into the unmute position.
If that brings back the sound of the keys, then it's safe to change the lock settings back to lock rotation.
If that doesn't solve the issue then I would recommend you do a backup and then restore to factory settings using your computer and iTunes.
Hope that helps!
Aug 21, 2012 | Apple iPad 32 GB 3G Tablet PC
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
External vga display doesn't work
Check external monitor settings on Fijitsu.
Jul 03, 2017 | Fujitsu Siemens Stylistic ST5022 Tablet PC
I have locked my MID Android Tablet. I have forgotten the pattern, So is there any one who knows how to unlock the pattern?
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
Nov 01, 2011 | Coco Android 2.1 Tablet (837121001186)
Front buttons doesn't work (MK1) and also FN-tabs. Is there a driver for this problen?
Go there :
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Choose your model, OS, language.
Select Category=All Drivers.
From the list, download and (re-)install the Hotkey Manager Driver, Hotkey Settings Application, and Hotkey Appendix Application.
Oct 20, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
I have the Archos 101 internet tablet but have been having trouble connecting to the wifi recently, I try to connect to a secure connection (I have the password and it is correct as I did connect a few...
Hi there. I noticed that sometimes Android devices seem to have trouble connecting to certain access points or.they seem to stop connecting alltoghether to certain routers. Sometimes this method can help: Select the network you are trying to connect to and select "forget this network". Reboot the tablet and try to reconnect again. Sometimes this doesn't work on the first try. If that doesn't work I have heard of other fixes but they require "rooting" the tablet which could be potentiall dangerous. Another thing you can try if that doesn't work is change the security to a different encryption type. Your password will either be WEP or WPA. Whatever it is try to change it to the other. I cannot give you detailed instructions on this because I don't know your router model or its current settings. Hopefully this helps and leave a comment if you have further questions. Good luck!
Sep 09, 2011 | Archos 101 Tablet PC
My Android Cruz Reader R101 starts on the Cruz flash screen, skips then goes back to Cruz flash screen. I have reset it using the reset between the power and External SD card. I also removed the back and...
This sounds similar to something that happened when I tried rooting my android phone. If it's the same thing, that means you will need to go to recovery mode and install an update.zip package that you can find somewhere online for it. It's because the code for what's supposed to happen after that screen is overwritten and it doesn't know where to go.
May 06, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Tablets & eReaders Logo
321 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
