Do you mean slow printing at work? You're question is not very specific. In case you mean at work, it can be because of too many print jobs which are too big. Thin Print is a software which amongst other features compresses print jobs pretty well. Here is a video aboot that: https://youtu.be/HBt8BDXBntU
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
·Printer driver settings
·Size of the data being sent to printer
·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue. Steps to fix Epson Printer Slow-to-print issue: Step1: Observe the data cable
Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays. Step2: Paper type
Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate Step3: Some general tips
Click on icon shown for general information on how to remedy slow printing Step4: High Speed enabled
Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections. Step5: Enable High Speed
Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress Step6: Other Settings
Check for other settings as well in speed & progress for better printing speed Step7: Spool folder
Create new folder of spool on the hard drive and point the driver to it Step8: Carry a test
Print a test page form general tab of your Epson driver Step9: Perform
If printing is still slow try reducing the size of the data sent to printer
You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Hi there:
The main cause of slow printing is due to a bad print cartridge. To troubleshoot this please remove one of your cartridges and see if your printing speeds up. If that does not work. Replace the cartridge and remove the other cartridge. If your printing speeds up. That print cartridge is at fault.
the print file detail may be multi-layered may be too much information in print job- your printer memory may not be adequate, you may be printing through a slow network, you may be printing through an older print server which is as slow as parallel port printing or you may be printing through your parallel port which is slow.
Remove both cartridges, switch off printer and then on. After cartridge holder comes to the center install both the cartridges. Then it will print the Alignment page. After alignment page prints place the Alignment page on to the scanner and press SCAN button as mentioned in the Alignment page. After completing the scan try printing. It will print the usual speed. Note: For the alignment process both cartridges should in good working state
Printing in color is always slow vs. printing in B/W. If your printing color with the highest resolution setting, it will print really slow. You can adjust the resolution settings in Printer Properties for the Lexmark.
If you want faster print, select a lower resolution.
You need to change the pickup roller. The rubber dries out and it is not able to pick up the paper quickly. I had this problem with our printer at work. We changed the rollers and its printing like new again.
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
What model? Is it a deskjet? If so, they are typically slow by nature :)
