My Nokia C6-01 keeps beeping for no reason.the charging is full , no messages received.Dont know how to stop that.Also sometimes the Screen just apprears to dissolves going black n the phone restarts.Could anyone guide......
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Stop whining and log into Nokia Suite (free).. Download it to your com if you haven*t. - Then you have the interface to do things with your stuff on your phone - mostly delete or just remove back to your com... You can always keep your phone on MAX TAP by using this but always keep space for vids and stuff... (music actually, at least in my Nokia goes to separate file spot. I delete and add all the time music)
Your Uniden phone is beeping because it alerting you to a message notification.
Charge your cordless; check the message; or this phone will keep beeping. Check and clear all notifications and messages, the phone will stop beeping.
Let me know how this worked out for you. If my solution helped you, please rate this solution! It doesn't cost anything and only takes a second, but it is greatly appreciated. KittyTech
You will have to restore the factory settings of Your phone to be able to stop this problem. Since deleting all the messages did not solve the problem. First of all, be sure that the message you are trying to receive is not a multimedia message, like pictures, music/songs and videos, because those files require a larger space to be able to receive such messages.
To restore The factory settings of Your phone,
Properly charge Your phone,
Go to the menu,
Select the settings,
In the settings, scroll to restore factory settings,
It sometimes prompts You for the phones security code,
Enter the security code of the phone,
A page will come on showing a loading page, once it has completed its loading,
The phone will be restored to the way it was when You first bought the phone.
Hope this was helpful. Thank You for using FixYa!!!
Hope this information helped You. Thank You for using FixYa!!!
the main reason the phone says memory full is if your text message inbox/outbox/drafts are full so try deleting all the ones you dont need.
Also another way of freeing up loads of memory would be to delete all the ringtones you dont use such as the ones you get free with the phone as you dont tend to use these so deleting them will free up loads of memory.
Also delete any pictures you dont need as this to takes up loads of memory so try deleting as much as you can as this will then free up your phone ok.
Let me know how you get on or if you need further assistance ok
Just like a message alert pop up, when you receive a picture message on your Nokia phone, it will show you "1 Picture Message Received" on your phone's screen as it beeps.
There can be several reasons for this beep:
1. The phone needs a good charge before using again.
2. The phone was default programmed to beep when not on the base.
3. There is a message to be retrieved which has not been located and looked at yet.
4. Another set has left a message and needs retrieval.
These are a few.
I hope this helps, let me know
Your manual will tell you about this on page 4.
Brother it is software problem in your phone, I doubt it is due to file infected by some virus. It is advisable to disinfect both your MMC and phone . For that you can reset your phone on factory setting by using it's menu and format/disinfect your MMC by any updated virus programme on pc. It will solve your problem.
If it sounds works then vote it here.
I had the same problem.
Here is the solution that I received from Motorola tech support:
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
