cleaned lint tray and lightened the loadkenmore elite dryer model number 11061082000
E1 error shortly into the drying cycle
yes i have the same problem, I have a kenmore elite gas dryer with a constant E!1 error code that shuts the dryer off constantly. Clean the lint extensively but still have the code.yes i have the same problem, I have a kenmore elite gas dryer with a constant E!1 error code that shuts the dryer off constantly. Clean the lint extensively but still have the code.
AnonymousJul 17, 2008
Same problem E1 after a short amount of time drying. Dryer shuts off. Had vent cleaning done and still a problem. Same problem E1 after a short amount of time drying. Dryer shuts off. Had vent cleaning done and still a problem.
Havving a constant E1 error code on my Kenmore HE4 dryer after only 3 minutes of drying. I have replaced the thermostat and still have the problem. I have cleaned the vent extensively.Havving a constant E1 error code on my Kenmore HE4 dryer after only 3 minutes of drying. I have replaced the thermostat and still have the problem. I have cleaned the vent extensively.
I have the same problem with my front loading kenmore h3 dryer, I get the E1 error message after a few minutes and the dryer shuts off. The only way I can dry my clothes is on the air mode. I have extensively cleaned dryer from lint and all the ducting from dryer to outside of home. Help?I have the same problem with my front loading kenmore h3 dryer, I get the E1 error message after a few minutes and the dryer shuts off. The only way I can dry my clothes is on the air mode. I have extensively cleaned dryer from lint and all the ducting from dryer to outside of home. Help?
AnonymousOct 03, 2008
I have the same E1 error code. I think I'm going to go buy a basic dryer. I thought this one would be nice. It's just been a pain in the ***; the washer is just as bad.
I have a kenmore elite electric dryer, I get an E1 error, and can only dry my close using the timed dry cycle, set on low. What should I do to fix this problem, Any help would be appreciated. I have a kenmore elite electric dryer, I get an E1 error, and can only dry my close using the timed dry cycle, set on low. What should I do to fix this problem, Any help would be appreciated.
AnonymousMar 18, 2014
error d90 on kenmore elite dryererror d90 on kenmore elite dryer
AnonymousMar 20, 2014
code OP what does it mean? dryer shuts off and this code shows up.code OP what does it mean? dryer shuts off and this code shows up.
You can't post conmments that contain an email address.
The fault code E1 means the electronic control detected the thermistor is
open. It's either the wire harness connecting the thermistor and
electronic control is broken or the connection is loose or the
thermistor is indeed open. Measure the resistance of the thermistor then
refer to the temperature and resistance table for the normal
thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
The electronic control detected the thermistor is
thermistor is indeed open. Measure the resistance of the thermistor then if it reads open or the harness of broken. Refer to the detailed troubleshooting of this error code in the link provided below.
I have a Kenmore Electric HE3 dryer that displays the E1 error code. My husband is good at fixing just about anything so he wants to fix this himself. Is this the Thermistor? Where is it located?
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
I went on another site where I found out that it was a thermistor a part of the heat blower. I will be ordering it for $20 off that site and my husband will fix it.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems.
if they are not serious, or they are a temp glitch!
How old is the appliance?
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
I have the same problem.
Model #11094836201
I have He3 and it shuts off after a short while and the E1 code comes up
