Question about Faberware 12-55 Cup Coffee Urn
Spout drip faberware coffe pot model 55
How to fix a dripping spout on model 55 coffee pot?
    Scholar:
  • 176 Answers
Hi. Go to repairshack.con for parts. bobbyone
Posted on Aug 11, 2010
SOURCE:
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
Am looking for an instruction manual for a Faberware 10 cup coffee maker
Hi, Farberware only makes 4-8-12 cup coffee pots and they all use the same manual. I have some. contact me through callahanronald@att.net. Ron
Jan 29, 2010 | Faberware (R) - Black - Ten cup capacity...
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Can I adjust the water flow for finely ground coffee?
You probably have coffee ground for a drip coffee pot, not an automatic drip coffee maker. With a drip coffee pot, you put the coffee in and add the hot water on top of that. You might want to try a coffee press. They are fantastic for the finer grinds of coffee. Some Mexican coffees are ground almost as fine as flour and a press works great. You can get a press for about $12 & up.
Jan 30, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffe comes out in a longer than usual drip
See my B30-solution; same procedure!
http://www.fixya.com/support/t2900087-bosch_benvenuto_tkn68e75_coffee_maker
Jan 12, 2009 | Bosch Benvenuto B20 Espresso & Coffee...
GE 4 cup coffeemaker Replacement Pots
I found them on amazon, click here and take a look: Amazon com ge 4 cup coffee pot replacement. have a nice day
Oct 04, 2008 | GE 106591 Coffee Maker
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
Faberware 12-55 Cup Coffee Urn Logo
185 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Bob Janelli
Level 1 Expert
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
