Question about HP Pavilion dv6000z Notebook
Showing the icon in taskbar. - HP Pavilion dv6000z Notebook
    New Friend:
  • 4 Answers
Please elaborate.
If you just want some icon to appear on your taskbar you just need to drag and drop it there, that's it!
Hope that helps!
Posted on Aug 08, 2013
SOURCE:
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Sound not comeing at the takbar speak not show
Show the volume icon in the taskbarIf you end up finding to impractical notification area to have the speaker icon displayed inside the taskbar, you can tell Windows 7 to resume showing the volume, same steps as before:
  • Click on the start menu, and type "volume"
  • Select the Volume's dropdown menu, and change its value from "Off" back to "On"
  • Click OK to confirm and close the Control Panel
Windows 7 has now resumed displaying the volume icon in the taskbar!
Else IF windows XP
goto control panel click sound and audio device then check Place volume icon in the taskbar.
Aug 15, 2011 | Computers & Internet
The volume icon on my taskbar has been deleted from my computer how can I download it again
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
Hope it helps.
Nov 22, 2010 | Microsoft Windows XP Professional
Sound icon doesn't show up on bottom toolbar
Right click on any blank part of your taskbar, then left click on Properties, a windows titled "Taskbar and Start Menu Properties" will open : click on the "Notification Area" tab, then, under Syatem Icons, put a check mark on "Volume", then click on "Apply", click on "OK" and the "Taskbar and Start Menu Properties" window will close and you will have the Volume (Sound) icon in the Notification Area of the Taskbar.
Sep 19, 2010 | Computers & Internet
I'm trying to get the volume icon back on the taskbar and the box that says Volume under where it says which icons will always show won't let me check it
Which window are you using currently, should mention first. I will give you common suggestion for xp. Go to control panel > click on Sound and there is the option to choose show/hide the icon on taskbar. if the box is already check for showing the sound icon on taskbar, just uncheck the box and click Apply, again click "check"box and click OK ..Hope it will show now.
Further please let us know. For more help please stay connected with Fixya.
Thanks for joining us.
Have a nice day.
Aug 29, 2010 | Toshiba Satellite A65-S1362 Notebook
Sound icon not here
To place a volume icon and sound icon in the taskbar follow these steps.
For Volume icon:
1. On Control Panel, double click Sounds & Audio Devices icon.
2. Select Volume tab
3. Check the box for "Place volume icon in the taskbar"
4. Click OK.
For Sound Icon"
1. On Control Panel, double click Sound Effect Manager
2. Select General tab.
3. Check the box for "Show icon in system tray"
4. Click OK.
I hope that solves your problem.
Please comeback and rate this answer. Thank you for using Fixya.
Aug 16, 2010 | Microsoft Windows XP Professional for PC
Volume Icon has disappeared.
First, right click on the taskbar and select Properties from the right click menu.
Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
The Volume Mixer icon will now show up in the notification area of your taskbar
I hope that this information was helpful and thank you for contacting the experts.
Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
Windows XP taskbar has "relocated itself"
Right-click the taskbar and ensure it's not locked..
Then just click on the taskbar and drag it to the bottom of the screen..
But i didn't understood the iconzied windows thing.. omg
PS: Please rate this solution
Mar 11, 2009 | IBM Lenovo ThinkPad T60
Lan Card Icon not showing in Taskbar
I think you need to reset the setting for showing on task bar, as in de-select the option, click ok, and then go back and select to show in task bar.
If this does not work, you system tray on the taskbar may be hiding some icons.
Mar 04, 2009 | Dell Inspiron 1100 Notebook
M2000 battery and very slow
The Power Options icon wont move to the taskbar. Double click on this icon, this opens the Power Options Properties window. Go to Advanced then select and select and tick Always show icon on the taskbar then apply. This should put the icon in the taskbar.
Try freeing some space using disk cleanup. You can also go to Internet Options to delete files stored in history.
May 06, 2008 | Compaq Presario M2000 Notebook
HP Pavilion dv6000z Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
