Plummer came and cleaned machine.....not all of the water draining
and there was a white film all over the dishes. Recommended that I use less soap.......problem no better. Please advise
Buy a name brand powder (like Electrosol or Cascade) and use less than full in the dispenser cup.
Do not use gel or tablet, ever.
Final option: (the perfect fix, expensive, but worth it... install a whole house water softener and cut the use amount of detergent in half that you use in both your dishwasher and clothes washer. You will love it.
If problems continue, have the heating element checked/replaced. When it fails, you will always get film/residue on dishes, especially your glassware, even if your water heater is set to the proper temp of 120 degrees.
Good Luck!
You may have something else going on with the plumbing if it is not draining well. That could easily cause isses. I have a low cost try that may help. I started the rinse cycle, once it was full of water, used 1 cup of white vinegar dumped it in the bottom and ran it through. 20 min. Then ran another rinse cycle to wash it down. Next load came out 5 stars! Just like new.
very good points. There are many possible causes. All you can do is start with the most likely. When we moved into our new house, we had that problem intermittantly. We eventually found that the softener backflush cycle was set too low. By the end of the week if we had a lot of usage, we ran out of softwater and had residue on the dishes.
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
