SOURCE: Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
SOURCE: my brand new 1.5 hp,
It is probably only getting 115V from your circuit which will cause it to overheat and trip the overload yet it will not draw high current which would trip the breaker. Can you confirm your line voltage with a meter? If it is suppoed to be a 230V line then look for a bad leg of power, again, checking each leg to ground using a meter.
John
