The cold air works and fan. When I turn the heat on high it blows air, but its cold. If I put it on low, auto, or med it hums. Its an electric thru the wall fedders ac unit. Any ideas?
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
i assume u r refering to the cooling fans,,, if this is so the freon is low ,fans come on and lower the high side ,there fore lowering the low side and the low side switch cuts it off and on,,charge it up
