My honda would turn over but not start, i replaced the fuel filter and i have fuel pressure from the pump. Still would not start, I checked spark and had spark but lots of oil around plug boot. Replaced the spark plugs and it started immediately. Drove 20 miles and at low rpm it wants to stall. My question is can all the oil around the plugs cause it to foul out and is it a seal that might be leaking.
Yes the oil can cause the car to lose spark, the oil leak could be caused by the valve cover gaskets around the spark openings, but 9 times out of 10 it is the spark plug tube "O" rings. The top of the valve train comes off of the head, the "O" rings are between the two halves, that will fix the oil leak.
Oil is gettin into to my spark plugs makein it mis fire. changed the valve cover gasket in it stil does... how do it get that to stop
These have problem matic distrubtor parts so you should check for spark if you have spark then go on to replace parts as needed and the oil is from a bad valve cover gasket
Yes it is possible.Oil tends to rubberize the wires and it turns them to mush.The oil leak is from the valve cover gasket change that and it shouldn't get them saturated any more..HOPE THIS HELPS YOU AND HAVE A GREAT DAY
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
I HAVE RECENTLY PURCHASED A 1992 HONDA ACCORD EX/EX-R WITH OIL ALSO AROUND THE BOTTOM OF THE SPARK PLUG AREA CAUSING THE CAR TO HESITATE WHEN I AM IN THE DRIVE POSITION AND I'M AT A STOP LIGHT. THE CAR HAS SHUT OFF ON ME, AND IT TENDS TO LOSE POWER. I HAVE HAD 2 SETS OF SPARK PLUGS PUT IN, AND THE AUTO SPECIALIST SPRAYED A CERTAIN TYPE OF CHEMICAL ON THE BOTTOM OF THE SPARK PLUG AREA TO DRY THEM OUT, AND SO FAR, IT'S OK.
I have a 92 accord lx it started once but will not start agian.. The battery was dead so we jumped it any suggestions?
the same thing happened tomy car yeah its foul out when you drive it should burn out of there thats what happened with my car and my accord has a very low idle it always has about 700 rpms
