How to hook up a xbox 360 console to my yamaha 6130 receiver
I have a yamaha 6130 receiver and energy 5.1 surround sound. i only need surround sound coming from my xbox and still have hdmi for my tv can someone help me?
Re: how to hook up a xbox 360 console to my yamaha 6130...
You will need an additional HDMI cord...you can get them without getting ripped off by purchasing at bluejeanscable.com.
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
Hook all the positive and negative wires correctly and read on the speakers and make sure you have them all in the right spot and if that doesnt help its probably because the reciever is maxed out wich is triggering a kill switch wich some recievers have as a safety feature so you dont blow your speakers
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Ok,you basically sent the audio OUT of TV and INTo your iputs on back of your Amp,you should be able to DL a manual on your unit,if you post more info ,I will try and help you Rod
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
