RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
Anonymous Posted on Apr 01, 2009
The battery on my blackberry 8310 went dead. I
The battery on my blackberry 8310 went dead. I plugged in the charger. The red light lit for a few seconds and then went out. The a picture of a battery with a lightning bolt came up for a few seconds and went out. After that, nothing. I bought a new battery and the same thing happened. Any suggestions?
  • Anonymous Apr 24, 2009
    I have exactly the same problem including that thunder lighting thing. Please help somebody .... this is so friggin pissing off!
  • Anonymous May 19, 2009
    hi i have the same problem and i have no waranty so please can you tell me wich part of the cell phone i have to buy to fix the problem. my email is [email protected] so you can send me the info on what i need to buy to fix my problem please. Thank you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3753
Points
9
Ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Anonymous
Level 1:
  • Posted on Apr 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3753
Points
It turned out that the usb interface on the blackberry went bad. If I had more experience, I would have known right away. Here are the conditions:
The battery was dead. I plugged in the charger. The led showed red for a few seconds and went out. A few seconds later the battery icon with the lightning bolt appeared for a few seconds and then went out. I now realize that when the icon went out, the charging had stopped.
I got ahold of a charged battery and the blackberry turned on.; When I plugged the balckberry into my PC, the PC did not detect it. My conclusion was that the USB interface on the blackberry had failed and could neither communicate nor charge the batterty.
Solution: Since the unit was still under warrenty, I called AT&T. They FEDEXed a replacement which arrived the next day. Also using the charged battery, I copied recent address book entries (in the failed blackberry to the SIM card before transfering the SIM card to the replacement blackberry.
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jun 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
6414
Points
22
I need youre help maam/sir my 8120 blackberry usb port leg broken how to fine usb ways this my unit!.....plz help me....
1helpful
Will not charge
You can re charge your battery by the electrical charger or change your new battery instant of your old battery.
My blackberry 6310 just stopped functioning , tried replacing a new battery ,still no good ,Any ideas ?
my blackberry 8310 was low in battery had red bar then turned itself off i plug the charger in and it comes on red for a second, then the little egg timer comes on now and agan then turns itself off
Blackberry 8310 curve wont turn on!
take out the battery and put it back in after about a minute
1helpful
My 8320 wont power on battery went dead and now wont turn on
Take the battery out, plug the charger in, put the battery back in and leave the phone for a few hours, the phone will turn on when its ready, by letting the phone go dead a cell in the battery went criticly low and it will not work again untill the battery gets above that critical point, if the phone will still not turn on after that u will need a new battery. this happens in older batterys
1helpful
Phone won't turn on
Try removing your battery and replacing it in the phone.
if you don;t get any results, buy a new battery.
As long as you haven;t dropped the phone or got it wet. Replacing the battery should handle your problem.
you can also try a different charger before you go to the battery.
Good Luck
2answers
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
Hello, my godmom just purchased a Brand new Blackberry Curve phone.When the saler put the battery in the phone, it didn't power on and she said that the battery was not charged and that we had to charge...
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
