SOURCE: No power - Nothing happens
if you have power at the outlet and the internal fuse is okay, I would say you have a problem on the control board. We repair these nationwide for $32.50. Please see my profile for the Web address: http://tinyurl.com/yzjozk
SOURCE: Thermal fuse MW8102SS Emerson microwave
normally the THERMAL FUSE is located in series with the 20 AMP power line fuse ,in most cases. hope this helps
SOURCE: micowave new but not working
This is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or occasionally a
problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch
or mount trouble can be caused by slamming the door or by opening the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount or
door alignment issue.
If you or someone you know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
Since
it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
SOURCE: My Emerson Microwave Model # MWG9111SL keeps blowing fuses..
You have a shorted high voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing [email protected]
SOURCE: Our microwave oven Emerson 8992SB
Here is a link to your microwave's Online User Manual in case you don't have it already:
http://www.emersonelectronics.ca/emerson/documents/MW8992RD%20-%2009%20Cubic%20Ft%20900%20Watt%20Microwave%20Ovenmanual.pdf
On page 13 of the above manual you will find instructions on how to deactivate the child lock in case that was the problem.
Basically you just hold down the STOP/CANCEL button for 3 seconds.
If it is not that then you might be looking at some kind of power supply circuit board or control circuit board failure and some significant disassembly since I don't believe there is an easily accessible fuse you can replace in the unit.
Good luck and I hope this was at least a little helpful.
Joe.
