My Frigidaire washing machine (9 cycle, 2 speed) will not move on to the next cycle. When put on the 15 minute cycle, it will load the water into the drum FOREVER, but won't overflow (so I guess it drains at the same time), but never goes to the next thing in the cycle. If I put it on Spin, it will spin FOREVER, but won't go the next thing without me manually turning the knob there. It seems to me that it's working fine, but just won't advance by itself. What is wrong with it?
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Hello James, thank you for your post!
I understand that your Frigidaire washer will start to agitate and no water will enter the drum. This could be an issue with your water valve or the control panel. I would check to make sure the water lines are opened and the connections are not restricted or damaged. If the water hoses are not damaged you may need to have a professional technician out to perform a proper diagnosis. This will help you to avoid any unnecessary part purchases. Good luck! -Matt
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
If it is draining while it is filling, your drain hose is either too far down the drain or not high enough from the ground. That will cause it to siphon while it is filling and never start the cycle.
