Question about Hotpoint NVL333EY Electric Dryer
Took it apart to fix heating element but cant find ill. to put it back together
  • Anonymous Apr 28, 2009
    same tumbles but no heat
    Habit-Forming:
  • 140 Answers
It might be a good idea for you to call an appliance service who specializes in repairing appliances like these. That way you don't have to worry if you are doing it correctly or not. If it were me then I would not want to take the chance of making a mistake and ruining the appliance. http://www.appliancerepairspokane.com
Posted on Dec 11, 2018
    Sergeant:
  • 254 Answers
SOURCE:
I have a Bosch nexxt 500 series dryer. The heating element wouldn't heat. I took it apart cleaned it put it back together and now all it will do is click
Make sure you have returned all wiring back to correct positions and that the drive belt has been refitted correctly.
Feb 28, 2015 | Bosch Dryers
My maytag dryer gets way to hot. you cant even get your near heating element. you can even see it glowing. what could cause that.
Were you running the dryer without the lint screen in place? sound like you got something on heating element. Also the heating element does glow orange when it's on. If it keeps on getting too hot, there is a sensor that shuts off element after a certain temp. This may not be working right. Just what I came across working on my own in the past.
Sep 11, 2012 | Dryers
Polohunt1@aol.com my bionaire bch9221 120 volt heater does not produce heat anymore.....i'm thinking that maybe an element within the unit is burned out.
Mine was doing the same thing. Took it apart and found that the white wire which hooked up from the circuit board to the heating element had burnt which broke the connection...hence no heat....replaced burnt wire and resoldered to heating element...put it back together and voila I have heat once more....still doesn't solve why the wire fried though....
Oct 13, 2010 | Bionaire Heating & Cooling
I just recently took apart my GE Dryer, model number DJSR473ET1WW to fix a loud noise. I put it back together and now I realize that the back of my dryer is extremely hot. Is there something I may have...
Sounds like you hava a venting problem. Disconnect the vent on the back and see if it still gets hot.
If it gets hot when the dryer is not on, then the heating element coil is shorting out on the element pan.
Hope that all helps.
Jan 15, 2010 | Washing Machines
Parts left over after replacing element!
here is a link to pictures of the assemblies. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=GJP84902&pop=flush Eric
Sep 14, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
HAVE DEHYDRATOR THAT DOES NOT HEAT ANYMORE
Take apart the bottom unit that contains the heating element. Hopefully it's put together with phillips screws. Mine are not. I'd have to drill out the brads that are holding it together. Once it's apart, use an Ohmmeter to check the heating element. Be sure to disconnect the fan from the heating element when ohmming out the element. If the element is open electrically, replace it. Good luck in finding a place to purchase a new element.
Sep 12, 2009 | Nesco Gardenmaster Digital Food Dehydrator
I need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Aug 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I took apart the trigger on my tec-9 and cant fix it
I did the same thing, and haven't been able to shoot mine for 4 years! Can you help. Just a picture of the lower reciever would do it. jbirm420@gmail.com
Apr 14, 2009 | Remington Sport & Outdoor - Others
Cant put the car seat back together
took the straps off and can't put back together
Apr 02, 2009 | Cosco Alpha Omega 22-180 - with Shield
Electric dryer...turns on, runs...no heat
heating element is bad unplug machine access the heating element it should have a break in the coil if so twist the coil back together gently though put it back in and try it i didi it to minr 6 years ago and no problems and you save a ton of money.
Mar 16, 2009 | Dryers
Hotpoint NVL333EY Electric Dryer Logo
1,166 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
