I tryed to replace the belt for my dryer when i put the belt around the pulley and then the drum,there was still alot of slack. is there something else im suppose to put the belt around or through.thank you
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
what is the idler pully assy there is this metal piece that is sitting at the bottom of the dryer that looks like you might have to slip the belt under. is this the the idler pully assy, thanks
dryer blows heat but not turning
