Question about Lexmark T 640 - printer - B/W - laser
Lexmark T 640 leaving faint black lines on right side of page
When printing on regular sized paper there are faint black lines about .5 inch wide entire length of page on the right hand side of paper. laser cartridge is relatively new. I also don't know what to do to maintain this printer.
Recommendations? Thank you.
  • barb_almy Apr 01, 2009
    The problem as reoccurred after the recent replacement of the cartridge. It was severe prior to replacement. The lines were gone for a short time and have now come back with new cartridge too.
Replace your cartridge, and all should be fine.
Posted on Apr 01, 2009
  • Anonymous Apr 01, 2009
    Are these remanufactured cartidges? You could have a bad lot.
    To isolate for sure, print several pages, then immediately remove the toner cartridge, and slide back the Drum shutter on the bottom (if it has one), if the drum has streaks of toner, the cartridge is absolutely the problem. Return them for a credit.
    If the drum is clean, then the problem is almost certainly the fuser. That would require a replacement assembly and a technician.
    Please rate me
SOURCE:
How to add custome page size to tallygenicom 6306 printer with windows xp i have to use width 15in height 12 please rplay soon
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Sep 21, 2011 | TallyGenicom 6306 Matrix Printer
Will not print bottom of page im printing water bills 3 bills to page will not print bottom 4 lines of bottom bill
You must see the size of paper is the same of the indicated in the printer driver or program.
Feb 22, 2011 | Lexmark T 640 - printer - B/W - laser
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Allignment is off on a lexmark x6150
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Press the "Options" button 9 times. "Maintenance/Align" should now appear in the display screen.
2. Press the "Right Arrow (+)" until "Test" appears.
3. Press "Select."
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 14, 2009 | Lexmark All-in-One Printer with PictBridge
Faint one inch wide line appears at the same time, every time.
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
Apr 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Optra T610 Print Problem
Your paper size settings for Tray 1 is probably wrong. Make sure it is set to Letter and the type is Plain Paper. If your Paper size is Universal, then either the paper guide in the tray is set wrong or the paper size sensor is broken. If the sensor is broken, you can disable auto paper size sensing so the printer will allow you to specify a paper size. To disable paper size sensing, you need to go into Config Mode. The other way is to send a PJL command to the printer to disable the function.
Nov 07, 2008 | Lexmark Optra T610 Laser Printer
Lexmark X3350 printing
i just fixed this problem.  first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges.  follow that, it solved my problem.
Jan 29, 2008 | Lexmark X3350 All-In-One InkJet Printer
Lexmark T 640 - printer - B/W - laser Logo
490 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
