Computers & Internet Logo
A
Anonymous Posted on Jul 30, 2013
Datamngr Coordinator has encountered a problem
rajeev kumar ranjan
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 12, 2013
rajeev kumar ranjan
Contributor
Level 1:
Answers
Questions
0
Helped
1898
Points
0
Datamngr coordinator.exe encountered a problem and needed to close
Datamngr Coordinator has encountered a problem and needs to close. We are sorry for the inconvenience. HOW TO SOLVE THE PROBLEM?
You have a virus. Run a virus scan, also Malwarebytes is an excellent tool. Download it here.
https://www.malwarebytes.org/dl-confirm/
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
You have malware. Use software like Malwarebytes to remove it. https://www.malwarebytes.org/
Sound like you might need .NET installed, you can make a short cut on Win 7 desktop and check application on the list box. Here is a tip to make that easy short cut link on your desktop.
  • Right Click on an empty area of your Desktop
  • Select >New > Shortcut
  • In the "Type the location of the item, type:
  • C:\Windows\System32\eventvwr.exe
  • Click on Next
  • Give a name to the shortcut
  • Validate with OK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
http://answers.microsoft.com/en-us/ie/forum/ie9-windows_vista/what-is-datamngr-from-bandoo-media-inc/539f373f-3703-497c-94da-e0fbd90be5b0
1helpful
How to solve the below problem in windows xp systems "Datamngr Coordinator has encountered a problem and needs to close".
you can try this go to start and computer local disk right click and click on tool. click on check now click start and click on schedule disk check. and restart the system.. if this not fix the problem you can delete the program it cold be a virus..
1helpful
DATAMNGR COORDINATOR HAS ENCOUNTERED
Depending on which level of risk of the Pup.datamngr virus has infiltrated your PC, you might find it is hard to get rid of this sophisticated worm. Some people have successfully cleaned out the stubborn worm, but since one of the primary functions of this virus is to disable security programs,so the method of using anti-virus program is not always a foolproof approach.
Please follow these steps to get rid of Pup.datamngr virus manually:
Step 1: Press CTRL+ALT+DEL or CTRL+SHIFT+ESC. Open the Windows Task Manager.
If that didn't work, try another way. Press the Start button and click on the Run option. This will start the Run tool. Type in taskmgr and press OK. This should start the Windows Task Manager
Step 2: Within the Windows Task Manager click on the Processes tab. Find the process by name. random.exe. Then scroll the list to find required process. Select it with your mouse or keyboard and click on the End Process button. This will kill the process.
Step 3: Delete malicious registry entries.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\random
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\run\random
Step 4: Remove malicious files of Pup.datamngr virus
C:\windows\system32\services.exe
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr)
C:\Program Files\Search Results Toolbar\Datamngr\SRTOOL~1\searchresultsDx.dll (PUP.Datamngr)
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
