F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
F8
Oven door lock failure
Check lock relay and door switches.
OK, there are two issues here. the oven door lock relay has failed then, shortly after that failure, the oven control board failed as well. this is a combination failure that incorporates two devices that will need to be replaced or repaired in order to restore this unit to optimal performance.
please rate and god bless.
When checking the F8, there may just be a malfunctioning switch that isn't communicating with the relay. you can test the switches with a multimeter for continuity.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
