Just recieved a beverage air model mt17 cooler the fan runs all the time tried the switch and had no effect
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
The switch is probably for florescent lights or a door frame heater.
Why do you think its for a fan? Does it say fan on it?
JUST a stab at why it says fan.
1 If it really turns the fans off it is probably for loadign in new product to keep from blowing out the cold air.
2 If it does not thurn off the fan someone put that on and it may be up-side-down it may have nothing on the other side.
3 Door Door Frame, or glass heaters (to keep it from sweating or moisture from forming on the glass door frame or door(s)
In costal areas the humidity is higher and it may have an option for this.
If it isnt one of these 3 Im not sure what you have??
Bev Aire 17??? I can try a phone call if I can remember to do it.
The switch is for condensation, for when it's humid, and that is per the Bev Aire web site.
I have a MT 12. That switch does start up the fan next to the compressor if the compressor is off. However, I am unsure if it is a defrost switch. If the switch is off and the compressor is on, the fan runs too.
It could be a defrost switch, however, this would pretty silly to make such so accessible.
i understand the compressor fan runs when cooling the inside evaporater fan runs all the time what would the fan switch inside the cooler be for there are two switches one for the light and one for fan thanks for any help
thanks for the help yes it says fan on the switch
