Televison & Video Logo
Posted on Apr 01, 2009
LG Blu-Ray BD-370 unlock codes
I have a LG BD-370 Blu-Ray player. The DVD is region locked to region 4 (Australia). I need the DVD unlock code to make this machine an ''all region'' DVD player as I have many different region DVD's.
Also, is there an unlock code to allow it to play other Blu-Ray region disks?
  • 9 more comments
  • sinpoo Apr 06, 2009
    Need to unlock LG BD370 DVD/BD for region free
  • Anonymous Apr 12, 2009
    Same as above, LG BD370 locked to region 2
  • Anonymous Apr 15, 2009
    Mine is stuck on Region 3!
  • Tarkan Apr 18, 2009
    Similar problem. LG B370 Blu-ray player locked to Region 4 B.
    Want to play my large number of region 1 A disks (USA).
    Anyone have an unlock code?
  • actualair May 04, 2009
    Can anyone report if this works for playing all regions of blu-ray discs?
  • Anonymous May 05, 2009
    does this really works because it says for DVD players not Blu-Ray?
    Thanks
  • Anonymous May 08, 2009
    The lg6000.zip solution works great. Thanks !
  • Anonymous May 13, 2009
    I have a LG-BD-370 bought in the US and it now plays all regions thanks to the lg6000.zip file above, thanks cydinajax!
    Just a couple of clarifications as the readme was a little off.
    1) when you un-zip lg6000.zip you'll get a folder called "RMTM0000". Put that folder (and its contents) on the CD.
    2) No idea how to not burn a "joliet" CD on a Windows machine without using a 3rd party app so I used a Mac running Leopard. Note this doesn't burn a "pure" ISO-9660 CD either but the BD-370 doesn't seem to care.
    3) This is just funny - after putting the CD in the machine and getting the "set the DVD region screen" prompt come up I was momentarily annoyed because the instructions said to press the desired region. Well I don't have a "0" button on my remote, rats! Then I realized there is a little door in the bottom of my remote behind which there are all sorts of buttons including a "0" - yay! I sat down and watched "A Matter of Loaf and Death" imported from the UK. Smashing that!
  • tbiviano May 25, 2009
    I have the same problem but when I read this message board I cannot see the file anywhere to unlock its not on the screen here. Can someone send me the link or file I need to burn to unlock my lgbd370?
  • Anonymous Jun 04, 2013
    Need to unlock LG BD560 for region free
  • Anonymous Mar 31, 2014
    I need to bypass region code for LG HB806 Blu Ray player. Code requires 2 letters
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
43752
Points
48
  • Anonymous May 01, 2009
    As per previous link I posted.Download lg6000.zip and your problem is solved.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
39862
Points
39
To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive.
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
  • Anonymous Oct 13, 2012
    does this work on a BP620??
  • Anonymous May 05, 2013
    no. it not worked in BP620
rkcole
Level 1:
  • Posted on Jun 15, 2009
rkcole
Contributor
Level 1:
Answers
Questions
Helped
39862
Points
11
Http://www.multi-region.net/_media/6000.zip Download this file unzip it to a folder on your hard drive.
Burn the downloaded file RMTMOOOO AND ITS CONTENTS onto a CD disc Make sure the disc is then finalised and closed.....
Enter disc into machine a blue screen appears PRESS 0 on your remote of the BD370 then pause.
To check this open the disc door and re enter the disc and it will show the region is 0.
My biggest problem was finding the 0 on the remote there IS a door on the top lower end slide this and a numberd key pad shows. Most have not been able to find this door.
if I can help [email protected]
  • Anonymous Apr 21, 2013
    Burn the downloaded file RMTMOOOO AND ITS CONTENTS onto a CD disc Make sure the disc is then finalised and closed..... this is best but i did my unlock with a rewriter able cd
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
39862
Points
6
Just to confirm this works a treat, many thanks.
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
39862
Points
6
6000zip works just perfectly - thanks so much!
Anonymous
Level 1:
New Friend:
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
39862
Points
Go on LG website and download a previous version of the firmware. Put it on an USB key and start the player to downgrade your firmware. The region free cd will now work. When done you just have to upgrade to the latest firmware as you did previously and voila !
  • Anonymous Dec 30, 2009
Anonymous
Level 1:
  • Posted on Oct 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
39862
Points
I BOUGHT LG BD 370 BUT UPGRADED THE SOFTWARE IS THERE ANY WAY I CAN STILL MAKE IT REGION FREE BY USING LG6000 PLEASE IF ANY ONE HAS SOLUTION PLEASE ADVICE
Anonymous
Level 1:
New Friend:
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
39862
Points
I HAVE BD 370 LG BRAND IT'S ALREADY MULTI REGION FOR DVD FORMAT BUT I NEED ALSO MULTI REGION FOR BLURAY FORMAT. PLS CAN YOU GIVE ME THE PROGRAM TO DECODE THE BLUE RAY. MY EMAIL [email protected]
Anonymous
Level 1:
  • Posted on May 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
43270
Points
7
6000zip works with Lg bd300 Blue-ray?
Anonymous
Level 1:
New Friend:
  • Posted on Feb 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
39862
Points
BE AWARE: THESE SOLUTIONS ONLY MAKE YOUR BLU RAY PLAYER REGIONFREE FOR DVD - NOT BLU RAY!
DVD USES NUMBERS FOR REGIONS, BLU RAY USES A, B OR C.
Anonymous
Level 1:
New Friend:
  • Posted on May 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
39862
Points
I am totally okey with solution#8. Fisrt all: Updates firmware from lg.com and your BD 370 will be alright. Will not necessary lg6000.zip.
Anonymous
Level 1:
  • Posted on Nov 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
39862
Points
I have the same problem as solution 8 - I just get a disc error. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Posted on Nov 04, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
39862
Points
Having a problem with hack. Anyone know how to check firmware? Burned ISO disc and player just ignores it. Looking for solutions.
Thanks in advance
1helpful
4answers
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
2helpful
I RECENTLY BOUGHT LG BD 550 ..THE PROBLEM IS I HAVE REGION code 2 DVD WHEN I INSERT DISK, DISPLAY SHOW "CHECK REGION CODE" SO WHAT CAN I DO?
it depends on what region your player is, most likely you need to unlock your region code(if there is an available unlock for your player) if you want to play that disk. but it simply means your dvd and your player is not on the same region
1helpful
BD-P3600 region code change from B to All A,B,C I have blu-rae movire in both A and B formats and can not view that do to the region lock on my blu-rae player rang samsung onlt to be told to go look on the...
The region is hard coded into the blu-ray. A blu-ray purchased in Canada or the US cannot be made to accept all regions. You need a unit from another country like Europe or Australia.
Australian region code
Australia and new zealand DVD playes usually are region 4 only this means the DVD is probably imported. You will need a multizone DVD player to watch it.
region A = region 1
region B = region 2
etc etc
Hope i could help
CBZ
Comment if you need more assistance
7helpful
2answers
LG BD300 dvd palyer region free code
2answers
Samsung bd-p1400 will not play certain disks
My dark Knight DVD was only playing the first 4 screens and I burned the firmware upgrade to a CD. It took about 20 minutes from the time I inserted it for it to be complete, then it stopped at 4 again but took about 30 seconds and it began to play perfect.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
