I have a 10 year old GE projection TV Model#46GW945, that has a slight curve in the picture. Also the colors are not lining up(cccooolllooorrrsss)imagine every other one of these letters being a different color^. I inherited this tv and am looking for a easy fix or just want to know if I should just "toss".
SOURCE: GE Model 46GW945 is now showing 3 different color pictures.
convergence circuit problems. prob why blew fuse,
SOURCE: picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
SOURCE: Seeing double pictures/letters on my rear projection big screentv
Start by replacing STK's IC.
SOURCE: Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Testimonial: "This is by far the best response I have ever gotten on any question. Clear, concise and directed me to the source I needed to fix the problem."
