If you are saying it starts and then dies, have you checked fuel pressure again ? Could be the fuel pump relay.
SOURCE: 1995 toyota camry-stalling out when driving
You do not have to replace the fuel pump at a specific mileage.
I hate to speculate without physically inspecting the vehicle, but, my best solution here & now may be the fuel pump. Now, I would not go out & buy one before you had proper diagnosis. Here is one test, but you will need to have to experience the stall again, and then test to see if you have fuel pressure at the injectors. If you have no fuel pressure, replace the pump. Fuel filter issues do not "come & go", they stay, and your car would not run properly. Also, a fuel pump failure will not set a computer code on this particular model vehicle. Hope this helps..
SOURCE: STALLING PROBLEM TURNED INTO NO START 1990 MB 300 SL
hello,good day,first we are in fuel side,better to install a fuel gauge,to determine the right pressure, is not mention your fuel pump relay,this should also check,some occasion the power supply is missing,now if all is in order (fuel side) then your switching unit(transistor box) need tobe check,assuming your engine is 103 engine,ty
SOURCE: wont start security light stays on
Body Control Module (BCM) on both counts. Find a shop in your town that specializes in electrical systems to test it. Beware, these can be intermittent problems, so make sure they keep it until the car does what you have observed. Expect to spend about $450 for the replacment. Dealers quoted me between $700 and $1,100 for the same repair. By the way, a new BCM will probably only last you about 12 months.
First time back in a while, finally getting nice here in New England. I bought my 67 GTX at a small classic car dealer a couple hours away. It looks great and is very stock original, auto trans, as far as I know matching numbers, I can certainly tell he engine is at least date code correct. (HP C 440 stamp on top front) Anyways, the day I bought it, I was on the highway home, stopped for gas and it was stalling at idle in Drive, as in slowly driving up to a gas pump, it stalls. By this point, the car was hot (not overheating, good temp but very much warmed up) When restarting, it cranks for a while before it starts, and then you have to keep the rpms up to keep it going. I didn't think it was an issue because I have a trusted mechanic at home and figured I'd have him look at it, adjust and I'd be all set. I took it to him, he adjusted the carb (original Carter AFB) and sent me on my way. Again, once it got hot, stalling like crazy at slow parking lot trolling speeds. I took it back to the mechanic, he said the carb is really bad and that he noticed an electrical line labeled "choke", which tells him the guy that traded it in took off a newer electric choke carb and put this old one back on before trading it.... Its been rebuilt and should be replaced with an Edelbrock to make life much better. I'm fine with that, so I bought an Eddy 850 and he installed it. It ran MUCH better (and faster!) cold, but still, once it gets hot, it stalls like a **** at slow speeds. It was the end of the season, so I waited til after the winter and took it back to him this week. He verbally told me it sounded like from what I was describing that it might be running lean. Okay, he kept it for a day, checked the plugs and claims they were "perfectly tan" so he was not convinced it was lean. He ran some tests on meters and told me he saw no valve or compression issues evident, it "runs strong". He actually changed the springs in the carb to lean it out more because he thought maybe the vaccuum was low and the springs were too hard for the carb to open. He also adjusted the timing. I took it home, ran great while cool, but again, stalling when hot after about 30 mins of driving.
I've had my mechanic for several years. He's a guy in his 50s with classic cars of his own and always cool to go to his shop cuz he always has many classic muscle cars he's fixing for people. He's a great mechanic. I truly believe that and he rebuilt my 67 Mustang and made it sing and dance. I know he knows his stuff. If anything, he tries like hell to fix things the easiest way before digging real deep and diagnosing as a more major problem. In other words, he doesn't like to do major surgery before fixing it the most easy way first. I am geting the feeling that there may be something more of an issue here. When I bought the car, it was described as just having an engine rebuild with a new slightly hotter purple cam but SUPPOSEDLY still standard bore.
What COULD be the issue here? Could I be looking at something major in this engine, and if so, what are some things that it could possibly be. Or is this common trial and error adjusting timing and the carb jets etc. It just awfully weird that even a new carb had no impact on this issue and it still stalls exactly like the day I bought the car with an original, banged up old carb.
