Question about Motorola Mobility V365 Cellular Phone
Inserted boost mobile sim card into AT&T Motorola V365
Put the battery back in place and turned on the phone. On the screen it read "Enter Subsidy Code" I have no idea what that code would be? If I was able to get the code, would that then let me use the AT&T cell phone, with the Boost mobile sim card?
  • 77 Answers
It can not work at all, boost mobile uses IDEN which is different from GSM. even if you unlocked the phone it won't work , sorry
Posted on Aug 02, 2009
SOURCE:
Tip
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction...
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 07, 2011 | Cell Phones
I have a t-mobile razor v3 and i want to use it with a at&t sim card. When I put in the at&t sim card and turn on the phone it prompts to enter subsidy code. Can someone please email me the subsidy...
You will need contact your service provider to get the subsidy unlock code to use your phone internationally or on another wireless carrier. They can walk you through how to enter the code in properly. It is free of charge.
Mar 07, 2010 | Motorola Mobility SLVR L7 Cellular Phone
SGH-A167 SAMSUNG - subsidy unlock code needed
call your carrier. (at&t, verizon etc.) give them your imei number. you can find it under your phone battery on a sticker. it is 15 numbers long. call your carrier and give this code to a mobile customer care representative and they should give you a 8 digit subsidy unlock code. Then once you get your subsidy code power your phone off take the battery out along with the sim card, replace the battery but leave the sim card out and power the phone back on, then when it gets to the menu screen punch in #7465625*638* and after that last star put in the 8 digit subsidy code your carrier gave you and your phone should say network lock deactivated. hope this helps.
Jan 14, 2010 | Samsung SGH-A137 Cell Phone
Subsidy Unlock code for att lg gr500
Make sure the phone is on so that you can enter the appropriate code. The unlock code is *#865625#.
  • Entering the code
The phone needs to be on for you to enter the appropriate code. You will need to keep the SIM card in the phone so that it recognizes the phone's unlock code. Enter *#865625#. The screen will then ask you if you want to continue. Select yes.
  • Second code
You need to enter the code a second time. So basically, just repeat the first steps mentioned to enter the unlock code given above. Once the code has been entered a second time the screen should read that the 'Network Unlock is Deactivated'. The code and the unlock work for the GSM network, meaning that if you want to use the phone with a different service provider you are now able to.
  • Other unlock
Sometimes one does not want to unlock the phone for GSM network use, but because the keypad is locked. If you have locked the keypad and this is what you want to unlock try the last four digits of the phone number. This is often the default code for the number pad. If that number is unsuccessful consider what you might have personally used as a four digit pin. Most of us use the same number that belongs to our ATM or other device that requires a four digit pin.
If the code provided in the first steps is not the correct one, you may want to look for a sixteen digit code on the back of your phone. It may be on the battery or just behind the battery. It tends to look like a barcode. Sometimes companies use this code as the locking mechanism for the GSM network. Tolearn more you can see our unlock-any-lg
Dec 23, 2009 | LG Xenon GR500 Cell Phone
Subsidy code for motorola i90c
When the phone asks u 4 the code just take the battery out and keep it out 4 a few mins and then put the battery back in and the phone shouldnt ask u 4 a subsidy code anymore
Mar 12, 2009 | Motorola Mobility i90c Cellular Phone
I have a motorola that is asking me for a subsidy password? how can i fix this problem?
To get rid of that message you need to take the following steps.
  1. Obtain a Subsidy Password, also know as an IMEI unlock code. The Motorola subsidy password is an 8 digit code that unlocks your phone for use with other cellular providers. Search Google for Motorola Unlock Codes for a list of retailers. Codes are usually provided within 48 hours, and cost around $30.
  2. *Most providers will not issue the unlock code after your account has been inactive for more that 90 days. They says it is because your account info goes into a "read only" status, and they cannot retrieve the number any longer.*
  3. Enter the IMEI code into the phone. To enter the IMEI code into the phone, all you need to do is insert a SIM card from a different network to the one that your phone is locked to. This will prompt the phone to display "enter subsidy password". Just enter the 8 digit code, and your Motorola phone is unlocked.
Please rate FixYa!
Jan 13, 2009 | Lands Phones
Nextel i870 subsidy lock code
my motorola i870 is asking for a subsidy code.
Aug 16, 2008 | Nextel i930/i920/i870 Stereo Headset [OEM]...
Unblock/subsidy code
There is no subsidy code. You must use the correct SIM Card.
Feb 18, 2008 | Motorola Mobility i836 Cellular Phone
Motorola razr V3 subsidy code
Motorola
> Subsidy Unlock Process
> With non-Cingular SIM inserted in device
> 1. Turn on handset
> 2. Enter unlock code when prompted
> 3. Press OK
> 4. Device should now be unlocked.
Dec 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V365 Cellular Phone Logo
143 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
