In one of my canon manuals is says about E.. (see the little dots)
Camera malfunctioned. Turn off the power and turn on again, then re-shoot or play back. If the same message recurs frequentely, the camera may be damaged. Note down the error number [xx] and take the camera to a custumer support help desk. If this message happens immeadiately after you have taken a shot, the camera may not have shot the picture. Switch to play back mode and check whether the image was actually recorded.
Sorry if I can't help you more, but Canon does not give more information.
You have 2 choices here, one is send the camera into Canon for exchange or replace the Camera, this would be based on cost. You can't fix it as no parts are available from the manufacturer to the public.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Hi:
It turns out that one of the wires connecting the LCD screen with the camera body probably is broken.
It is a simple to remove the LCD cover and reconnect the wire, but it requires manipulating very small objects. The clip that you must re-insert the wire into is scarcely 1mm x 4mm. I recommend a bright light, magnifying glass, tweezers, and a very small phillips screwdriver.
It might also be possible to aquire a replacement cable from Canon. E-mail them...
Regards
