Question about Cisco ASA 5520 Firewall
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
  • Eustache Duverna
    Eustache Duverna May 11, 2010
    Can you please clarify?
    1- are you trying to restore to factory defaylt?
    2- do you have a configuration file that you would like to import to the ASA?
  • 74 Answers
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
Posted on May 07, 2009
SOURCE:
Console to asa 5520
Your are correct, it is a 5520 ASA and thus it requires immediate attention. Console is dependent on the 5520 without a doubt and should you fail to connect them accordingly; the entire process will be in vein. Good luck Captain.
Jan 16, 2013 | Cisco As2511-rj Universal Access Server...
How do i configure pppoe on asa 5520 ver8.4 and remote access vpn?
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/pppoe.html
Nov 08, 2012 | Cisco ASA 5520 Firewall
How to block a port in cisco asa 5520 firewall
hi,
when u login in ASDM you can find on right side services and u create one whre u add which all ports u want to and apply that in ur rules
Aug 23, 2010 | Cisco ASA 5520 Firewall
How do I recover firewall password?
You may refer to the steps in the link below:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/trouble.html#wp1049302
I hope this helps!
May 05, 2010 | Cisco ASA 5520 Firewall
ASA LAN failover Problem
The crossover cable should work fine for sure.
Best Regards,
TL
Mar 17, 2009 | Nokia IP 350 Firewall
Export and import all configuration in Cisco ASA 5510
Hello ,
the Steps which u want to export and import configuration in Cisco ASA5510
1- connect yourself to your Cisco gateway by IP
2- Get TFTP server to your PC like( solarwind , Tftp server , ... ) any tftp download and upload program
3- now u need to copy running configuration to your pc by order
#copy run tftp , then follow the steps
NOTE: u should be in the same network or u need your pc and cisco box both have publick IP
4- if u want to put prepair config files to your gateway , you will need to type order
#copy tftp run , then foloow the steps
If u need anything else please let us know by leave your completely request or join us with www.fixya.com
Regards,
Samer
Dec 17, 2008 | Cisco ASA 5510 Firewall
PIX AND ASA Configuration
Voila un link pour un bon simulateur:
http://networksims.com/pix.html
Nov 20, 2008 | Cisco ASA 5520 Firewall
Problem in installing the asdm image ASA 5520 ver 7.1
I had this same issue on my ASA 5520.
1. Copy the config and IOS image to a tftp server.
2. Format flash (disk0)
3. set rommon server, ip addy, and file settings.
4. tftpdnld
5. Once the system has booted to the image copy the asa image file, asdm image file, and config to flash
6. configure asdm image default location and reload
Feb 27, 2008 | Cisco ASA 5520 Firewall
Cisco ASA 5520 Firewall Logo
670 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
