The eMachines T3058 Desktop PC uses an Intel D101GGC motherboard.
The plastic front of your computer is the Front Panel.
The rectangular area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Front Panel header:
This link takes you to Intel Support, and the download page for the motherboard manual, for the Intel D101GGC motherboard,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htmOn this page click on the blue -
Intel Desktop Board D101GGC Product Guide - English (PDF)
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
{ Took 7 seconds to download just now, with no additional download time needed.
Using medium speed DSL connection }
Ignore the following if you are aware;
At the top of the PDF file is the PDF file page number box, and the Zoom Out/Zoom In icons.
Zoom Out ( + ) enlarges the page view, Zoom In ( - ) reduces the page view.
For myself I reduce the view size to 100 or 75 percent.
The page number box is to the right of the Down Arrow.
(If you do not see this, hover your mouse cursor towards the bottom/middle. When the icons come up, {They were 'ghosted out'}, click on the PDF icon to the far right )
Provided that somehow you cannot download this motherboard manual;
Orient the motherboard so we are both looking at it in the same direction.
Same as it sits in the computer case.
Processor to the Top, Ram Memory to the Right, white PCI slots to the bottom.
The Front Panel header is at the Bottom/Right.
It is a rectangular block of plastic with two rows of pins.
4 across the Top, 5 across the Bottom.
It is numbered Even on the top, and Odd on the bottom.
Starting at the LEFT side going towards the right, on the top row;
Pins 2, 4, 6, and 8.
There is no Pin 10, just an empty space.
Starting at the LEFT side going towards the right, on the bottom row;
Pins 1, 3, 5, 7, and 9
A) Pins 1 and 3 are for the HarDDrive activity LED light. (Orange)
Pin 1 is for the Positive wire ( + )
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Blue)
C) Pin 9 is for 5 Volts. Not Used (Black)
D) Pins 2 and 4 are for the Power On LED light. (Green)
Pin 2 is for the Positive wire ( + )
If the LED light is dim switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Red)
Do not know what wires coming from the Front Panel are the Power On switch wires, Power On LED light wires, or Harddrive activity LED light wires?
Remove the Front Panel, trace the wires to the Power On switch. (Two wires. Probably twisted together. Or all wires are in a single sheath)
Same for the Power On LED light, and the Harddrive LED light.
Need to know where the harddrive, or optical drive plugs in?
Need to know where the power cables from the Power Supply plug in?
Please post back in a Comment.
Regards,
joecoolvette
