I have a Jenn Air Down draft slide oven Model # JGS9900BDS16. All of a sudden the "Warming drawer" light has turned on whenever I turn the fan on. I called Jenn Air and they had no direction on what the problem could be. Since the oven does NOT have a warming drawer I assume this is some sort of code for an error. I tried turning off the power for 1 min, and leaving the oven alone for another 5 with no success. The fan is blowing in the correct direction (I had been using the oven for more than 1 year). Any ideas?
SOURCE: Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
SOURCE: Oven light won't turn off
It sounds to me like the switch that operates the light is malfunctioning. You're taking the right steps by pressing the switch by hand. Since that didn't work, either that switch is not working or there is another switch that is intended to keep the light on while the door is closed. You can look at that one too. The last thing to consider is if the light is relay controlled, the relay might be stuck closed and applying power to the light all the time.
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
Why are the oven indicator lights flashing?
Answer:
When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
SOURCE: Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
same thing just started happening to mine
This same issue just started with our 3-year old Jenn-Air Slide-In Range. No mention in the Use & Care Guide. Any ideas?
Mine is doing it, too
Mine too
Mine now too any resolution?
