I have killed the power in an attempt to reset the machine. However, the ''Clean'' light returns to blinking when power is restored. Pushing the ''Start'' button causes the start light to blink three times, then the ''Clean'' light starts blinking again. How do I reset the dishwasher so that I can run it through the wash cycle??
If the clean light flashes 7 times, pauses, then repeats...
When
the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring).
It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
Hi r2strelioff,
Does the machine need cleaning? Most dishwashers require a cleaning routine usually with dishwasher salt to be followed when the 'Clean' light comes on. There may be a separate compartment inside, near the back.
Regards,
Mark.
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
• Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
• The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
the ''Clean'' light is blinking when power is restored. Pushing the ''Start'' button causes the start light to blink three times, then the ''Clean'' light starts blinking again. How do I reset the dishwasher so that I can run it through the wash cycle??
I had the same problem Ireset the control panel and everything seems to work ok at this time Thank you for the help
