LG RU-44SZ61D 44" TV Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg 42 inch projection tv has green light and orange light
The green light and orange light are on the front of the tv. Is the lamp about to go out?
  • Maddiegurl Apr 29, 2009
    orange means its overheated
Anonymous
Level 2:
  • Expert 261 Answers
  • Posted on Jun 29, 2009
Anonymous
Expert
Level 2:
Answers
261
Questions
0
Helped
65256
Points
714
It is a possibility, if the indicator lights are on it definitely means something is wrong in the light engine system, it could be your lamp, ballast, color wheel or dmd board, when it comes to LGs it's most probable that your lamp might go out. You can replaced it to see if it fixes your problem, if it doesn't, there's a chance it might be yoru ballast.
Red light only blinks
ON THE BALLAST SENSOR CONNECTOR AT THE ADaPTER CHECK VOLTAGES BROWN WIRE 0.1V,ORANGE-5V,YELLOW-3V, GREEN-5V. RED-GROuND. GR. CONNECTION IS OPEN. NEED TO JUMP IT FROM THE WIRE TO THE NEGATIVE SIDE OF THE FILTER CAP ON THE BALLAST, if this doesn't do it may need a new lamp.........good success, meder's tv service
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
1helpful
2answers
Orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
2helpful
WARNING LIGHT ON FRONT OF TV
Your Tv requires the lamp hours to be re-set. You will need to acess the Service mode settings via a service remote from your authorised LG service agent.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
