I just got a brand new Frigidaire fridge. This morning I opened the fridge and the refrigerator light was flashing very steadily on, off, on, off. It's one of the ones with the hallogen light and I just got this fridge last week. It works fine. The freezer works, the fridge keeps everything cold. None of the temperature lights are flashing and the fridge is not making any weird noises. It's just the light flashing on, off, on off. What could that be? I don't seem to be having any other electrical issues in my apartment.
SOURCE: THE FREEZER IS WORKING BUT NOT THE REFRIGERATOR
your defrost system is malfunctioning un plug refrigerator for about 2 hours replug and check if it makes a difference check if fan in freezer is working , you may need atechnician .
SOURCE: mfd2561hes Maytag Refrigerator
My Maytag mfc2560hes starting making a noise this am. I checked the fridge and everything is hot. The freezer is still cold, and the items are frozen. What am I to do?
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
SOURCE: Top mount fridge stopped refrigerating, maybe compressor?
It could be a bad compressor or the Start Relay that is bad, an easy way tell if the compressor is bad or not. If the compressor is hot to the touch it's probably the Start relay is bad, but with the Fridgeidare they have had some compressor issues. Good luck
SOURCE: Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Good Morning Brett, thanks for your inquiry!
I understand that your Frigidaire refrigerator is flashing a "4" and you would like to know what that means. The "4" on your display means that there is a damper failure within your refrigerator and I would recommend checking the damper in the rear of the refrigerator to assure it is opening and closing. The damper is located in the back of your refrigerator. I would place your hand back there to assure it is blowing cold air into your refrigerator.
If the damper is not working it could be a potential issue with your damper, main control board, or wiring harness. I would then recommend performing a reset on your refrigerator. You can do that by unplugging the power cord for roughly ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Hello erintu81 - SY CF typically indicates that the refrigerator has detected a communication failure after power up. The wiring between the main control board and user interface board will need to be accurately diagnosis. Depending on the results either or will need replacing. At this point, I strongly recommend connecting a professional to move forward accurately and to properly assist with the repair(s).
